torque converter flush
Old Jul 6, 2015 | 07:50 PM
justcruzin125's Avatar
justcruzin125
Hey guys, gonna flush my E4OD along with the converter. Question is....how do you fill the convertor? I know how to drain it.
Old Jul 6, 2015 | 08:34 PM
rla2005's Avatar
rla2005
You may find this article helpful: Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
Old Jul 6, 2015 | 09:14 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
the pump in the trans fills it if you want to drain it via the drain plug.simply fill the trans up and run the truck for a minute.shut it off and the fluid level will be lower and you can now top it up.
want a cleaner,easier flush next time? the 4r100 pan comes with a drain plug.they're about 40$ note; use the e40d 4wd filter with them.
Old Jul 6, 2015 | 09:56 PM
justcruzin125
Ok, so it fills its self, cool. Thanks
hav24wheel
Mar 6, 2013 01:44 AM
rmilchman
May 17, 2006 08:56 AM
Steve95
1978 - 1996 Big Bronco
Mar 14, 2006 07:57 PM
mike strahan
1997 - 2003 F150
Apr 24, 2005 03:45 PM
KennyG228
Feb 16, 2004 08:53 PM
