97 F150 odometer/tripcounter not working
Got a 1997 f150 97 is analog not digital so there is no blackout. Got the truck like this with the problem. It worked one morning then i pushed the reset counter and it stopped. I took out the gauge cluster and spun the gear i think by a tiny motor and the tripmeter worked along with the odometer adding a mile. So I know the gears are not striped. Any info??
i dont know about the F150, but the boy had a 95 Mustang with similar problem. The speedo worked, but odometer did not. took it apart and it had a stripped racka nd pinion gear. I know you said it is not the gear, but i would check to see if the speed and odometer have the same input. If the speedo works and the odometer does not, that narrows it down to the small gear box, i think.
Odometer/Trip Counter
I was finally able to remove the cluster and found the gear causing to
problem it was missing a tooth but it took along time to figure out how
to remove the gear, finally got the gear replaced and the instrument
panel back to gether and found that the gages were off, so after
spending some time trying to calibrate to gages, I gave up and went
online and found a used one with almost the milage on mine.
The price wasnt bad compared to what they wanted to repiar mine
/////approx 200.00 ///////////125.00 for the used one.
I really appriciated all the posts I got trying to help me.
Authenticraft
19
04-19-2024 08:53 PM
BrushPopper
02-05-2016 03:12 AM
