97 econoline odometer ?
Old Dec 1, 2012 | 07:49 AM
gyrocopter1's Avatar
gyrocopter1
I have a 97 E150 that the speedometer works fine but the odometer
does not register the miles driven. Has anyone ever had this problem?
Thank You Jim
Old Dec 15, 2012 | 12:51 PM
cjm808's Avatar
cjm808
Had same issue with a '97 E350 as well. There is a little gear that wears out-it's right on the odometer itself-if you pull the cluster you'll see it. We found replacement gear on ebay by searching 'Ford odometer gear' or something like that......cheap and relatively easy fix once the cluster is out.
Old Dec 15, 2012 | 10:24 PM
macattack's Avatar
macattack
I had a mercury cougar that had this same problem after 4 different clusters from salvage yards I gave up.
Old Dec 15, 2012 | 10:36 PM
tabijan's Avatar
tabijan
Which both begs and answers the question of how far you will go to repair an odometer
Sixto
'93 E150 Chateau 5.8 185K miles (I think)
Old Dec 16, 2012 | 06:21 PM
gyrocopter1
97 Odometer
It seems like a lot of work, I think a Hobbs hourmeter will tell me all that I
need to know for maintenance, just have to find the correct spot to hook into that is hot only when the key is on. Any ideas? Thanks for the info.
Old Dec 17, 2012 | 01:00 AM
95e150CW's Avatar
95e150CW
Its rather easy to get to the radio's key-on hot wire. 2 bits of coat hanger wire to pop the radio are all that you need. Yellow wire with a black stripe. Ground is black with a light green stripe, or anywhere metal.
Old Dec 17, 2012 | 02:49 PM
tabijan's Avatar
tabijan
If you spend hours upon hours with the key in the accessory position, tapping into a circuit that's only live with the key in the RUN position, like the fuel pump circuit, will be more representative of engine running hours.
Sixto
Old Dec 21, 2012 | 05:47 AM
JWA's Avatar
JWA
A bit late to this thread, apologies if the original problem has already been solved. Here's some info I posted a while ago about cluster anatomy--hope its useful: https://www.ford-trucks.com/forums/1...r-anatomy.html
stodd4
Sep 7, 2018 07:05 AM
DaviMac424
Feb 16, 2010 05:38 PM
carlsson01
Mar 31, 2009 03:28 AM
Forced347sn95
1997 - 2003 F150
Dec 13, 2007 04:21 PM
jecp
1983 - 2012 Ranger & B-Series
Dec 15, 2006 11:41 PM
