Mounting Hydraulic Ram on dana 44
See if you can look up a 78-79 F-250 that had the hydraulic steering assist as it will be basically the same mounting. I have been looking at this same solution for my F-150, and from what I have found, the easiest way is to make a mounting flange that bolts to the top, front of the diff cover and the ram pushes to the passenger side where you make another mount on the tie rod making it go straight in and out.
Check this page:
http://www.coloradok5.com/hydroassist.shtml
There are some good pics of how to make your mounting, just do it in reverse for your ford.
Check this page:
Most full hydro guys steer from behind the axle. There are plenty of steering arms available that will allow you to mount the ram bhind the axle, and steer from the back side of the knuckle on the pass side. It looks like a crossover arm, and bolts to the knuckle the same way, so some machining, and drilling will have to be done to the flat top knuckle. The radius arm will not get in the way, and will allow for full flex. Easier to do this with a 60 but it can be done with a 44. The advantage here is the ram is out of the way from front impacts.
I will look for some old pics I took out at Moab when I saw this set-up.
mountain dewd
12-07-2015 03:37 PM
RV_Tech
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
11-01-2012 03:53 PM
