Manual transmission Fluid?
Old 03-16-2007, 06:40 PM
ro1bvan1's Avatar
ro1bvan1
ro1bvan1 is offline
What type of fluid should I run in my 2001 7.3 6 speed manual?
Does it require any additive?
Old 03-16-2007, 06:42 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Plain ol' ATF. Or syn ATF...
Old 04-28-2009, 10:53 AM
mechelement's Avatar
mechelement
mechelement is offline
How much ATF did your transmission take when you changed the fluid? I want to order enough for my x-fer case and tranny.
Old 04-28-2009, 11:22 AM
krejci.mike's Avatar
krejci.mike
krejci.mike is offline
anyone have a good write-up of changing the tranny fluid in a six speed?
Old 04-28-2009, 02:05 PM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
Use Syn ATF. These trans get HOT! I've seen over 235* on mine. Mine runs about 180 on thy HWY. Make sure you can get the fill plug out before you drain fluid. Use a 3/8 ratchet or breaker bar with no socket. It'll take about 5.8 qts and the transfer case takes 2.
Old 04-28-2009, 02:29 PM
chayes01's Avatar
chayes01
chayes01 is offline
I have an '01 7.3 1 Ton Crewcab with a 6 speed. I flushed the trans and went back with synthetic. This is the only manual transmission with an internal pump that sends fluid to a cooler so I added a Diesesite fullflow external filter and temp gauge. I tow a 13K fifth wheel so I want as much filtering and cooling as possible. During summer running empty I'll run @ 130 degrees at highway speed and @ 180 degrees towing. It was worth the added expense to me.
Old 04-28-2009, 06:30 PM
mechelement
Thanks!
Old 04-28-2009, 06:58 PM
F350-6's Avatar
F350-6
F350-6 is offline
That's really all there is to it. Drain from plug on bottom, fill from plug on side. Takes about 6 quarts. I bought one of those lids that has the clear tube attached to it. Screw it on to the bottle of ATF, stick the clear tube in the fill hole, and turn the bottle upside down and dump it in, then repeat.
pchelp
18
07-13-2017 09:48 AM
nxtdiesel
2017+ Super Duty
06-26-2017 02:13 PM
texrdnec
2017+ Super Duty
05-10-2017 06:40 PM
corksil
10-25-2015 08:33 AM
F1DER
03-30-2012 05:10 PM
Quick Reply: Manual transmission Fluid?
