Headlight Switch replacement
From the FORD service manual ..............
Lamp Switch — Headlamp Printable View (41 KB)
Removal and Installation
Disconnect the battery ground cable (14301). For additional information, refer toSection 414-01.
CAUTION: Do not use a screwdriver to remove the headlamp switch or damage to the finish panel may occur. Adding tape to the end of a thin tool will reduce marring to the finish panel.
Insert a thin tool to remove the headlamp switch.
Disconnect the electrical connectors.
To install, reverse the removal procedure.
I guess they did change. You're correct for the '97 shown below without the pictures.
Removal
Turn the headlamp switch **** to the headlamp position and pull the ****.
Insert a thin tool to release the headlamp switch **** and remove.
Turn the headlamp switch **** 180 degrees and install.
Turn counterclockwise until the back of the headlamp switch **** is in the off position.
Turn the headlamp switch **** clockwise fully.
Remove the headlamp switch.
Pull headlamp switch from instrument panel.
Installation
NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive system may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
Removal
Installation
hi-jacker
1999 to 2016 Super Duty
05-15-2017 10:19 AM
TexasGuy001
04-13-2016 04:48 PM
Marky48170
03-18-2012 07:52 PM
