Sponsored by: Auxito
Headlight Switch replacement
Old Jan 27, 2007 | 11:55 PM
Smokefan420's Avatar
Smokefan420
I need to replace the switch in the dash in my '03 F150, How?
The part I picked up from wreckers is switch with bracket.
Old Jan 28, 2007 | 10:41 AM
ncranchero's Avatar
ncranchero
From the FORD service manual ..............
Lamp Switch — Headlamp Printable View (41 KB)
Removal and Installation
Disconnect the battery ground cable (14301). For additional information, refer toSection 414-01.
CAUTION: Do not use a screwdriver to remove the headlamp switch or damage to the finish panel may occur. Adding tape to the end of a thin tool will reduce marring to the finish panel.
Insert a thin tool to remove the headlamp switch.
Disconnect the electrical connectors.
To install, reverse the removal procedure.
Old Jan 28, 2007 | 03:37 PM
Smokefan420
Wow, thanks!
Old Jan 28, 2007 | 03:56 PM
ncranchero's Avatar
ncranchero
Not much to go on but better than nothing!
Old Jan 28, 2007 | 05:05 PM
galaxie641's Avatar
galaxie641
Did they change them in '03? The way mine works is you pull the switch handle off reverse it, put it back on and turn to release the clips, it is a major PITA but is a neat way they integrated everything together.
Old Jan 28, 2007 | 05:25 PM
ncranchero's Avatar
ncranchero
Well, I thought I had read different instructions on here for removing the switch but my post was copied directly from the FORD 2003 manual. You made me go back an make sure I checked the correct year ........ I did.
Old Jan 28, 2007 | 05:28 PM
ncranchero's Avatar
ncranchero
I guess they did change. You're correct for the '97 shown below without the pictures.
Removal
Turn the headlamp switch **** to the headlamp position and pull the ****.
Insert a thin tool to release the headlamp switch **** and remove.
Turn the headlamp switch **** 180 degrees and install.
Turn counterclockwise until the back of the headlamp switch **** is in the off position.
Turn the headlamp switch **** clockwise fully.
Remove the headlamp switch.
Pull headlamp switch from instrument panel.
Installation
NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive system may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
Old Jan 28, 2007 | 05:33 PM
ncranchero's Avatar
ncranchero
It changed in 2000 ........'97-'99 as you stated, '00-'03 as i originally posted.
Old Jan 28, 2007 | 05:36 PM
ls973800's Avatar
ls973800
I installed fog lights in my 2003 F150, and had to change out the factory headlight switch with a switch that had the fog light switch feature. The first post is how mine came out. I used a thin screwdriver with a rag covering the tip to prevent any damage to the dash opening.
hi-jacker
May 15, 2017 10:19 AM
candoo
May 19, 2016 11:45 AM
bigcrunch
Large Truck
May 8, 2016 11:52 AM
TexasGuy001
Apr 13, 2016 04:48 PM
Marky48170
Mar 18, 2012 07:52 PM
