Flathead multi carb linkage
Old 11-03-2006, 01:18 PM
464Saloon's Avatar
464Saloon
464Saloon is offline
Hi,
Just joined here. Have a Weiand 2x2 mainfold that I have had for years and am finally getting around to putting on my 51 F-1. Does anyone make any linkages to work with this set up?
Thanks,
Old 11-03-2006, 01:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I believe both Speedway and Flathead Jack have them, others probably do too. You are probably better off getting a "universal" kit that is adjustable. Are you going to use Holley 94's or Strombergs? Staying with the generator or using an alternator? (Clearance issues)
Old 11-03-2006, 01:45 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,930 Likes on 1,875 Posts
OK, first of all....I don't have a clue about the linkages, I think I have seen them in the Speedway catalog but thats where my knowledge stops.
Second, Welcome to the board!
Third, don't just tease us with small question about milti carb, give us some pics!!! (we love pics) Brag a little bit, tell us all about what you are working on, show us some pics, what that status of it is, pics, future plans, etc, etc, etc. Did I mention pics?
Good luck with it
Bobby
Old 11-03-2006, 01:55 PM
464Saloon's Avatar
464Saloon
I have heard that Speedway has them, but I can't for the life of me find anything in their catalog on line. I just got a paper catalog in last night so maybe I will find it there. Flathead Jack doesn't show anything online, they want you to buy their 10.00 catalog. I either have one buried somewhere or my Dad has it because he is restoring a 50 F-1. My 55 F-100 is purdy and has won a trophy or two, but the F-1 is still waiting it's turn. About the same condition as the truck on Sanford and Son. The manifold is setup for carbs close together in the middle so no generator issues there. Carbs are actually Ford 94 but I believe they were made by Holley. Used to be really up on the Flathead and Y-Block stuff, but have got a little rusty working on my two Oldsmobiles and my Hudson the last couple of years.
Old 11-03-2006, 02:46 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Welcome to FTE
Glad to see another Flatmotor person.
As Bobby said we like pictures (He likes them more cause he can't read.)
For a refresher on Flatheads go here:
http://www.btc-bci.com/~billben/flathead.htm
Old 11-03-2006, 03:03 PM
mtflat's Avatar
mtflat
mtflat is offline
Just remember you don't want progressive linkage with 2x2's or half your engine will run lean until you have your foot in it...unless the Weiand intake changed the runners from stock locations.
One problem with 94 on a reg dual intake is the rear carb's forward bolt on the bowl hits the front carb. That's why 97's were usually used. Or 94's on super dual intakes. Some guys get around it by grinding off the front bolt boss, hoping 4 bolts will seal the bowl.
Also you may have timing issues if using the stock distributor. It relies on venturi vac off the back of the carb body, not manifold vac. Not sure what might happen there. But if you don't get enough advance to run wot, look into it.
L M C truck has progressive linkage in their catalog. 3 1/2", 7" or 9" varieties.
Old 11-03-2006, 03:19 PM
464Saloon's Avatar
464Saloon
Well I didn't think Progressive would be a good idea with this setup either but you list here a place with progressive linkage which by the way I clicked on and all I saw on there was late model truck stuff. Have to look into that bolt up issue, hadn't thought or got to that point yet. Could just make my own linkage, but thought for sure with the popularity of the V8 and multi carbs, there would for sure be kits out there that would be easier to go with. Seems like you see that stuff everywhere until you want it. So what is the process for posting a pic here. Each forum I am on for my different cars is different and I have a heck of a time keeping memory on which does what.
Thanks,
Old 11-03-2006, 06:07 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Try Sac. Vintage Ford: http://www.vintage-ford.com/
In the Hotrod Section they have dual carb non-progressive linkage setups.
Old 11-04-2006, 09:48 AM
464Saloon's Avatar
464Saloon
Thanks,
I'll check them out.
Old 11-04-2006, 09:52 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 464Saloon
Hi,
Thanks,
"Say why and Weiand."
Check around at swap meets promoted by the Early V8 Club...and you might score the linkage at one of the older Ford Obsolete stores.
rswhitmore
01-10-2015 07:26 PM
rews2
03-27-2014 06:25 PM
chaseon
12-14-2013 04:14 PM
chaseon
12-11-2013 08:25 PM
Quick Reply: Flathead multi carb linkage
