Mustang vs F-150 water pump
Sup all? I need to put a new water pump in my '91 F-150 and I have a brand new pump from my brothers '90 Mustang. So, questoin is are they the same part? they are both 302's. The local autozone tells me that they are different part #'s, but they sure look the same to me. Maby its a different impeller or somthin. I dunno. Anyway, thanks for the help.
Truck 302 is prolly non-HO while mustang is HO(Roller block). I think the roller water pump may rotate differently.
The 302/5.0 HO mustang waterpumps up to and including '93 are standard rotation like the truck. In '94-'95 they went to the reverse rotation waterpumps which use a physically different timing cover and pump. The '90 Mustang pump will work. If not, I'm in trouble too 'cuz I just put one on my truck.
I was wrong:
Now I'm confused. My truck has a serpentine belt system. So does that mean it is reverse rotation like the Mustang? Or did trucks use a standard rotation serpentine? The belt takes an s-curve around the pump and balancer pulleys. I hate to pull it off the motor to check but guess I'd better.
Here are some pics I found of the internal differences between the standard and reverse rotation waterpumps: http://www.corral.net/forums/showthr...verse+rotation
Originally Posted by MurPHy4570
The Mustang has used a reverse rotation waterpump since 1979, when the serpentine belt system was introduced. You'll have to get a waterpump and timing cover from either a 78 or earlier Mustang, or a different Ford altogether (pickups had standard rotation into the mid 80s).
hush210
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
30
10-22-2018 01:55 PM
kdhannink
17
05-09-2013 11:13 PM
