6.0 exhaust
Old Feb 5, 2005 | 06:54 PM
tolliewolly's Avatar
tolliewolly
Smile 6.0 exhaust
I want to order the HOG exhaust for the 6.0 on motorhaven.com. It is 585.00 and I was wondering from you guys out there if I can install that exhaust system in my shop wihout a bunch of heavyduty work?
Old Feb 5, 2005 | 07:15 PM
beemr's Avatar
beemr
I would imagine you could unless it is an inferior system, which I doubt given Motorhaven's reputation....
Old Feb 5, 2005 | 07:32 PM
LOOnatic's Avatar
LOOnatic
[QUOTE=tolliewolly]I want to order the HOG exhaust for the 6.0 on motorhaven.com. It is 585.00 and I was wondering from you guys out there if I can install that exhaust system in my shop wihout a bunch of heavyduty work?[/QUOTE
Catback no sweat.
Harder if your changing the downpipe but totally doable yourself.
Have a good time.
You got gauges?
Old Feb 5, 2005 | 07:56 PM
tolliewolly
No i dont have any gauges...do I need them? I do also want to order that system and install it myself but everybody tells me I need to take it to an exhaust shop and let them do it in order to do it right.....is that true?
Old Feb 6, 2005 | 12:48 AM
Twin Tritons's Avatar
Twin Tritons
Here's a link to HOG's instructions. http://www.hogperformance.com/p_installation.asp
You can read them over and decide if you have the tools and mechanical aptitude to do it yourself. I didn't read over HOG's instructions, but MBRP instructions indicated an easy install. Some of the turbo back systems recommend you make a cut of the stock exhaust system rather then remove the transmission cross member.
Old Feb 6, 2005 | 08:32 AM
guydiver12's Avatar
guydiver12
exhaust
I was looking at MBRP exhausts, and their instructions say the system was made so you don't have to remove the crossmember, something about cutting or disconnecting in front of the crossmember. Looked very shadetree mechanic friendly. I once put a cat back on my F-150. Much more simple than a turbo back job, but it was extremely easy. The exhaust was a Gibson supertruck cat back, and everything fit like a glove. Took me less than an hour, lying on my back in the driveway, used a hacksaw to make things easier. I didn't see anything on the MBRP system that looked really difficult, except for the downpipe thing. I've heard it's a tight fit, and requires some patience. I love the diesel duals system. Something about dual 5 inch tips that would make this truck look like the bad boy it is.
Old Feb 6, 2005 | 08:49 AM
eharman's Avatar
eharman
I did the Hog cat-back by myself in a couple of hours. No problem.
I just shifted the spare tire over to the left alittle to give me
more clearance between the tire and the plastic boot cover on the shock.
I did not do the turbo back. I did not want to fool around with
the emmisons and possibly have FMC at me.
EJ
Old Feb 6, 2005 | 09:43 AM
King of the Road 04's Avatar
King of the Road 04
yeah it wasnt to hard to do the install.......as long as you get the right exhaust system for ur specific truck. Now im not too stupid, but when it came time to do this i was. It came in on a thursday, so when i got home from work i started hacking at factory exhaust to get it off, and when i went to put the new aftermarket, low and behold, it didnt fit right lol, so i didnt have a truck till saturday nite. To make a long story short, they sent me the turbo back system, i needed a reducer to neck the 4 in pipe down to 3.5 to fit onto the cat, and my hangar locations were all out of wack, im not sure why that was but i had bend, cut and weld new hangars up, but all in all it was fun, no better way to spend ur birthday i say lol. And i have the 6 in slant cut exhaust tip, much more noise than thr 4 in, get it, its worth it.
Old Feb 6, 2005 | 10:46 AM
guydiver12's Avatar
guydiver12
Uh-Oh, sounds like I'm going to the muffler shop for that project. If it can't be cut and bolted, I'm in trouble.
Old Feb 6, 2005 | 11:33 AM
SBV45's Avatar
SBV45
Here is Ford's service procedure for removal and installation of the downpipe for the 6.0 in the F250/350. The Ex has a different procedure. The procedure has illustrations that are marginal. If anyone is interested, send me a PM with your email address with a space on either side of the @ sign and I'll send it to you in Word format.
Removal and Installation
Vehicles with automatic transmission
Remove the transmission fluid level indicator.
Remove the nut.
All vehicles
Loosen the clamp and disconnect the downpipe from the turbocharger.
Remove the nuts and the RH intake heat shield.
With the vehicle in NEUTRAL, position on a hoist. For additional information, refer to Section 100-02 .
Disconnect the wire loom from the crossmember.
Using a suitable high-lift transmission jack, support the transmission.
Remove the nuts.
Remove the nuts, bolts and the RH crossmember bracket.
Remove the RH crossmember nuts and bolts.
Remove the LH crossmember bolts.
Remove the crossmember.
Separate the transmission fluid filler tube and position aside.
4x4 vehicles
Remove the nut, washer and bolt.
Remove the nut, washer, bolt and the right front stabilizer bar link.
All vehicles
NOTE: Lower the transmission jack approximately 25 mm (1 in) to ease the removal of the downpipe.
Remove the nuts, bolts and the downpipe.
To install, reverse the removal procedure.
Old Feb 6, 2005 | 11:45 PM
King of the Road 04
if u get the right cat-back exhaust for ut truck it should be bolt on, i didnt but since i didnt check i made it work, but from what i heard from numerous other people its easy, just make sure u get the right kit......
aaronlaaron
Jan 9, 2017 02:23 PM
jdkeifer
Sep 24, 2016 08:18 PM
Nathan
Dec 2, 2010 04:53 PM
aughtsix
Jun 2, 2010 09:12 PM
Motor3440
Feb 9, 2010 05:04 PM
