What a difference!
Old 10-03-2006, 09:53 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
The percieved HP increase is usually less than the advertised HP increase. Of course we all know that chipmakers would never over state the effectivness of their product.
As mods go starting with gauges is not a bad idea.
The Exhaust Mod with downpipe replacement will give you a little more responsive throttle, put a smile on your face, and actually help your truck operate more efficiently all at the same time.
Old 10-03-2006, 10:40 PM
jcab's Avatar
jcab
jcab is offline
Excuse Me, I Guess I'am Human!!!!!!!!!!!
BAYLIFF WACK MY YOU KNOW WHAT. ITFOX MADE THE INJECTOR COMMENT, YOU CAN TAR AND FEATHER ME. JCAB
Originally Posted by Phydeaux88
I said nothing about bigger injectors or anything past chipping.
What I said was if you want to chip do it right.
See Below:
The idea is to avoid spending money to repair your truck when the repairs could have been avoided by some minor mods.
Old 10-04-2006, 11:46 AM
wfodickinson's Avatar
wfodickinson
wfodickinson is offline
You are opening a huge can of worms if you change injectors from what I have been told. Intercooler etc.......
Old 10-04-2006, 08:26 PM
ltfox's Avatar
ltfox
ltfox is offline
Originally Posted by true
I am a little disappointed. I used to have a 2002 PSD and it had a great deal more power. It was equipped the same except it had 3:73's and it pulled much better than this 97 does. What do I need to do to get the power to be comparable to the 2002's?
Its really simple. He asked what ya got to do to make comparable power. The only way your gonna get it to pull with a newer powerstroke is to get bigger injectors......along with the supporting mods to make it safe and operate properly. Dunno what the big fuss is about the injector comment?
Old 10-04-2006, 09:37 PM
ForemanES's Avatar
ForemanES
ForemanES is offline
"What do I need to do to get the power to be comparable to the 2002's?"
ltfox you are correct, bigger injectors are the only way to keep up with the superdutys. Our stock 94-97 psd injectors are ~100cc, the 99+ superduty have ~130cc injectors. A chip can only take your stock injectored motor to a certain level around 220hp (and it still falls short or a stock superduty). The superduty can make up to 300 hp with its injectors and some programming. The only can of worns you would open would be that you will keep wanting more power from your motor, ie pms.
Old 10-05-2006, 04:25 AM
Flea's Avatar
Flea
Flea is offline
some questions after reading the posts:
1. What size is stock on DP and the rest of the exhuast
2. would it make a difference if the exhaust was split at where the muffler is located.
Reason's for asking:
I was just given what looks to be a 3 to 3.5" pipes from a dodge cummins that looks like the same size of the exhaust on mine. I know I probably can't use the DP but the rest of the straight pipe has a pipe to go all the way back and splits at the muffler location. I even think it fits over the axles correctly.
So, the new mod would delete my cat and big bulky muff. (Ha ha) and give me a split at the muffler location.
3. I did the DIY Tymar intake mod and I don't notice a big difference in noise. Does this help performance? I didn't notice a huge difference.
4. Also, once and a while, (twice a month), my tranny will not shift from first to second under acceleration. I have to let off of it for a second to get it to shift.
Is this common or would you recommend an immediate fluid replacement and filter kit from the local auto supply store or an upgrade from some aftermarket guy?
I also was considering synthetic fluid. What did it cost you do to it?
Sorry for all the questions combined into one thread.
thanks for the help.
Flea
Old 10-05-2006, 10:01 AM
ForemanES's Avatar
ForemanES
Flea I can answer a couple of your questions
1) the stock down pipe is not round in diameter, it is a flattened pipe used for the tight fit between the firewall.
2) The stock exhaust has a 3.5 inch diameter, but it is flattened at the bends. I think the basic fitment of the duals would work but you will have trouble mounting it up to stock locations.
3) This filter does offer better airflow to your engine but the biggest advantage from this setup is its filtering ability, and it creates a much better seal than the factory box.
4)
Old 10-05-2006, 12:23 PM
true blue's Avatar
true blue
true blue is offline
How do you get an after-market down pipe in? It looks like there is no room at all.
Old 10-05-2006, 04:44 PM
ltfox's Avatar
ltfox
ltfox is offline
http://www.drivetrain.com/downpipeinstinstr.html
Check out this link on downpipe install.....very good with pics.
Old 10-05-2006, 08:55 PM
F350_Hauler's Avatar
F350_Hauler
F350_Hauler is offline
Just a thought. Do a 2" body lift first. Makes it easy.
It was pretty easy to install a 2" Performance Accessory body lift and then there was plenty of room for the new downpipe. We did it to my son's truck and now I want to do it to my new truck, too. I'll have to wait a while for that, though. The body lift kit is cheap. I think I got his for $115 delivered. I will start watching for that on e-bay. It takes a full day to do the lift and the exhaust work but it is oh so worth it.
Old 10-05-2006, 11:17 PM
true blue's Avatar
true blue
Nice install instructions. Is a down pipe really worth the effort?
Old 10-05-2006, 11:19 PM
jcab's Avatar
jcab
jcab is offline
Pm sent to you
f350 hauler, I sent you a pm. I hope you got it. Jcab
  #28
Old 10-05-2006, 11:25 PM
Phydeaux88's Avatar
Phydeaux88
A 3 1/2 inch downpipe will fit without modifying the firewall. I must admit that some have found it easier if you remove or knock down the seam bend that runs thru the area. some aftermarket pipes are made in 2 pieces, supposedly easier to install. I dont know if that is true. I had mine installed by a local muffler shop -- these 65 yo bones dont take to lying on the ground under a vehicle very well.
Next go to 4 inch for the rest of the system.
It is the single most cost effective mod you can make. It helps the truck work more efficiently, reduces stress on the engine, and helps keep EGT down.
Open element exhausts dont boost performance so much as they help keep EGT down, somthing you will never know if you dont have gauges. I did get a very noticable increase in turbo whine when I changed.
  #29
Old 10-06-2006, 11:15 PM
Phydeaux88's Avatar
Phydeaux88
OOOPS
that should be open element air intake systems not open element exhaust
maximusfd
08-05-2013 06:52 PM
IMCO_Performance
10-08-2005 10:30 PM
2001_73_PSD
06-24-2004 04:37 PM
Brian429
Computer Chips & Tuners
09-02-2003 07:29 AM
JerryT
10-31-2002 12:00 AM
Quick Reply: What a difference!
