Chips/Tuners and plowing
DP-Tuner. So far nobody has said they regret buying his product nor has anyone said that they went his way then another way and are happier. Give him a call and he will advise you what you need. Few times I talked to him, he doesn't seem in a hurry to push a product. Asked him about the SCTII tuner and whether I would use it to the full potential. He basically said "If it were me, I would get it. You probably won't use it so much."
plowing snow is also extremely hard on transmission temps. if you add a chip, gauges are recommended so you can keep track of the tranny temps. if you have high temps, a huge cooler and electric fan are recommended as there isnt much airflow over it when plowing due to the slow speeds, and usually snow gets clogged up there.
GeorgiaBoy17
15
12-01-2013 09:30 AM
blhfla
15
12-16-2005 05:13 PM
