89 f250 front body mounts help
Hi,
My 89 f250 front body mounts are shot. I mean the part that they attach to is completely rotted away. (not the bracket on the frame, but the upper part above the body mount.)
It looks like it supports the radiator. Is there an easy fix for this?
What is the part called that the bushings are attached to? Should I go to a body shop or my usual mechanic? Anybody else ever have to replace this?
Sorry for so many questions, just trying to get things done before it starts getting cold around here.
Thanks,
Thanks,
That is what it sounds like. I think I'll stop by and see my body shop budy. After looking at it some more, I think that I'd rather have somebody thats done this before to fix it. Aparently this has bee like this for a while. I use the truck for plowing, and wonder if I can get away with another season of plowing or is this somthing that really has to be taken care of right away?
Received 3,108 Likes
on
on
grill, headlights, batteries, fenders, hood, a/c, radiator, power steering cooler(if equipt). basically anything that bolts to it needs to be removed.
i got an aftermarket rad support for $235 compared to the dealers $480 when i did mine in spring 2001.
and make sure you specify the type of engine you have. there are different rad supports for the gas and diesel trucks.
on
I recently replaced one on our '90 ranger. Removed the grill, headlights, front bumper and trim panel below the grill. Disconnected the upper rad brackets and moved the rad back, but didn't need to disconnect the hoses(manual trans). Didn't need to remove the fenders either, just unbolted them at the top to allow a little elbow room. Hood was off anyway but the hood on the F150 doesn't require a prop stick so it should be fine left on. The rad support is welded in on the Ranger, and it could be the same for the F150... not sure. I cut out the old one and sparked up the Mig and welded the new replacement back in.. only took an afternoon and the new aftermarket piece was $100 at the Fender Factory here in Ottawa. Fit was great.
Brown Falcon
10-20-2011 04:18 PM
WINGNUT-
08-11-2010 08:20 PM
Kirbys73F100
01-06-2010 11:18 PM
forddriver17
01-19-2009 10:41 AM
