Front body mount Part #???
Old Apr 4, 2011 | 12:21 PM
Brown Falcon's Avatar
Brown Falcon
I need to replace my front body mounts (up by the radiator/core support). Anyone have part numbers from Ford and a price estimate?
Old Apr 5, 2011 | 10:27 PM
Brown Falcon
bump...
Nobody has info on this part???
Old Apr 5, 2011 | 10:36 PM
Talyn's Avatar
Talyn
I thought you did a body lift, why do you need these again already?
Old Apr 5, 2011 | 10:40 PM
Brown Falcon
I'm taking the body lift off... don't like it when I'm hauling heavy stuff. I didn't gain anything from it really. Once I do my 4x4 conversion I would need it anyways.
All I can find in body mounts is poly stuff and I want stock rubber.
Old Apr 6, 2011 | 11:35 AM
BIGRED 7.3L's Avatar
BIGRED 7.3L
I don't know the factory part number. I know you can get them aftermarket at LMC and Jeff's Bronco grave yard. They are rubber. NPD might have the actual ford part. Doesn't really answer your question but it is all I got.
Old Apr 6, 2011 | 11:54 AM
pjwoolw's Avatar
pjwoolw
PM Ed. I'm sure they must be available from Ford. I couldn't find anything but poly either.
Old Apr 6, 2011 | 01:50 PM
BIGRED 7.3L
Look at these and see if this is what you need.
1980-96 Ford Truck/bronco - Bushings/polyurethane - Body & Hardware Truck
LMC Truck Parts - Page 163
Both Rubber and Poly options in these links so make sure you find the rubber.
Old Apr 6, 2011 | 09:01 PM
Brown Falcon
Thanks for the info James and Pete. I'm shopping around right now, probably won't get around to buying them for another couple weeks. Just want to get a good deal...
Old Oct 19, 2011 | 11:37 PM
creator's Avatar
creator
Part Number
Did you ever figure out the part number for the mount(bracket that attaches to frame). I need to replace my mount before I can do the rest.
I've read in some other forums people managed to get some from their local Ford for $12, but they didn't have part #'s.
I'm in a new area, and the Ford dealers are all far away. Not sure how helpful they will be.
Will probably just have to order one from Bronco Graveyard:
Radiator Core Support Frame Mount Bracket
Old Oct 20, 2011 | 09:29 AM
bearhugger's Avatar
bearhugger
Evan, I checked with ford a while back when i replaced my motor mounts,i dont have the part no. but they were way to high for me.i even got my motor mounts somewhere else.
JIm
Old Oct 20, 2011 | 09:41 AM
Brown Falcon
I just needed the rubber pieces for mine, not the actual bracket.
JIm
I got it figured out. The price for the factory rubber was way too pricey, but I found a old set of poly body mounts in storage that were originally for my '75 F150 I used to have and two of them in that kit were the same height that I needed to I just used those...
Old Oct 20, 2011 | 04:18 PM
creator's Avatar
creator
Found Number
Core Support Mount Bracket:
E6TA-5A041-AA
21.30 from Local FORD
lower cushion:
E2AZ5400155A
$13.45 from local FORD
Upper cushion:
EOTZ1000396A
$90+ from local FORD
Aftermarket kits can be purchased for far less.
Lane Locke
Mar 23, 2017 09:32 AM
melvinew2
Aug 24, 2016 01:51 PM
BAJI26
Jun 16, 2015 08:17 AM
ddivinia
May 6, 2012 10:32 PM
Kirbys73F100
Jan 6, 2010 11:18 PM
