1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
clicking sound from front end
Old 06-30-2006, 06:41 PM
alfama351's Avatar
alfama351
alfama351 is offline
04 f350psd 4x4 srw cc, lariat.
It started today, making a left turn from a stop sign, I heard a clicking sound coming from the front end, you can faintely feel it through the steering wheel as well, it does it making right turns as well, just not as pronounced.
The truck was loaded with my atv rack, two atv's and gear, about 1800 lbs.
Drove it yesterday, 300 miles, loaded exactly like I explained before and I don't recall any problems.
Haven't drove it empty since this happened.
I'm thinking U joint behind front wheels, It almost feels like when you have 4x4 engaged on pavement.
Any ideas or sugestions are welcome
BTW it's got 49.550 miles
Old 06-30-2006, 08:09 PM
kemerick's Avatar
kemerick
kemerick is offline
I had a faint clicking noise up front and it got louder and louder over months. It got faster relative to the speed of the truck. Dealer could not figure it out on two trips in. I was finally backing up with the door open looking at the back tire when I realized it was coming from the rear too.
...long story short it turned out to be the hubcaps on my Weld rims. Took them off, put a bead of silicone on the rim and torqued the bolts slowly to make the silicone stay put.
I doubt its your issue based upon you are thinking you can feel it through the steering wheel but just thought I would throw it out there.
Old 06-30-2006, 08:27 PM
alfama351's Avatar
alfama351
I've only felt it when making sharp turns
Old 06-30-2006, 11:30 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds like one of your front hubs is locked.
Or worse, the needle bearing the axle rides in is so shot that it turns whether or not the hubs is locked.
Reach around the back of the wheel and the spindle, and try to turn the axle by hand ... report back.
Old 07-01-2006, 12:12 AM
alfama351's Avatar
alfama351
Exactly what i'm I looking for? is the axle suppose to turn by hand?
Old 07-01-2006, 07:01 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Yes, it should turn by hand. Easily... well, somewhat with some drag, but easy enough, and SMOOTHly.
If it doesn't turn by hand, either the hub's locked, or the needle bearing went. In my 2001, the needle bearing was so bad the axle wouldn't turn by hand. But I resurfaced the axle, replaced the needle bearing, and everything's fine.
If you look behind the wheel, you will see the u-joint for the front axle. Spin it by hand. If it moves smoothly, no problems (be aware, this is really testing BOTH axles (the other one will spin the other direction) - so, to really check which side it is, jack up the front end and spin the tire).
Old 07-01-2006, 09:51 PM
alfama351's Avatar
alfama351
thanks
Thanks for the tips,I didn't get a chance to check it today, I'll try it tomorrow.
Old 07-03-2006, 10:52 AM
alfama351's Avatar
alfama351
Ok, it's hard for me to get my hands on the axle and turn it, but when I spin the wheel the axle spins as well, does this mean the hubs are locked? or is this normal?
BTW it's very hard to spin the hub lever ( lack of better word) from auto to locked.
If the hubs are locked, it it hard to unlock them?
Old 07-03-2006, 01:05 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Alot of times, the **** gets hard to turn.
Either the hub is locked, or the needle bearing is shot. When you spin the wheel, can you grab the u-joint and make it stop spinning with the wheel? Is it "crunchy" ???
Old 07-03-2006, 01:28 PM
alfama351's Avatar
alfama351
Ok, its not crunchy.
Driver side wheel and axle spin, can't stop axle from spinning when wheel is spinning, I'm guessing its a locked hub. Also can't rotate from auto to locked with out help from pliers.
Passenger side wheel spins and axle does'nt, when I spin the axle the wheel does'nt spin. Also can't rotate from auto to locked with out help.
BTW took a short trip today, first time since I unloaded it. I didn't feel or hear the clicking.
Also would you know if this is covered by ESP?
Old 07-03-2006, 02:22 PM
alfama351's Avatar
alfama351
bingo
I followed the instructions on the thread below and pulled off the hub and now the wheel spins free with out the axle. Can this hub be repaired or should I just bite the bullet and get the manual hubs?
https://www.ford-trucks.com/forums/s...8&page=1&pp=15
Old 07-03-2006, 03:16 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Do the soak-in-ATF thing that BFR250SD posted, get the ***** working, work them back and forth, and see if they unlock.
Many an auto-hub has been resurrected this way
Old 07-03-2006, 03:23 PM
alfama351's Avatar
alfama351
It looks like my curiosity got the best of me, I made the mistake of taking this thing apart, I'll never figure out how to put it back together.
So I guess I'll be ordering new manual locking hubs.
Thanks for your help and time
Old 08-01-2011, 09:55 PM
Patrick.2001F250's Avatar
Patrick.2001F250
Patrick.2001F250 is offline
Kyle Emerick thanks for posting on here. I have the same wheels on my truck and have had my front end looked at by 2 mechanics 4 times and no one could find the problem i have found some unrelated issues, but the clicking always comes back and it seems to go away every time the hub caps are pulled off and then comes back louder and louder every time again thanks for the post. A small tube of silicone will be so much cheaper than another trip to the mechanic
Tx Hunter
2017+ Super Duty
12-28-2016 07:04 PM
sinurgy
38
05-22-2010 09:02 PM
bucketosudz
01-07-2009 07:58 AM
erbenson
1997-2006 Expedition & Navigator
08-12-2007 10:37 AM
BillyBob69
1997 - 2003 F150
10-24-2005 10:12 PM
Quick Reply: clicking sound from front end
