All-Terrain Tires for 2004 Stock Wheels
Welcome to FTE!
It would be helpful to know what size you currently have on your truck, the OEMs do vary in size.
In my case, I have the 18'' rims, and I want BFG All Terrains, so that means that I will have to step up to 285/65R18's as they are the only 18" BFG's AT's unless I change rims.
Not a big deal as the step is small, and I do have a tuner to adjust the speedo. With rising gas prices, I have been thinking that I may have to skip the bigger tires. Time will tell.
http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
Originally Posted by page850
Im wondering what is the largest size tire I can put on my stock wheels without complications. Im looking to put an all terrain tire on.
Thanks for any input.
i put the 285 BFG AT's on mine, and my gas mileage dropped about 1.5 mpg. Not a lot and when you really factor in how much that will cost you a year, its minimal. Figure if you drive 15000 miles a year, that will add about $300 in gas or 111 ,more gallons.
However, the mental anguish of getting less mileage on an already needy vehicle is a different story.
Did you happen to get your speedo recalibrated? If not, part of the decrease in mileage could be attributed to this. Larger diameter tires would show up as less miles on your odometer. But, larger tires also weigh more (usually), and more rolling mass contributes to less mpg also.
X21bravo
6.7L Power Stroke Diesel
02-25-2015 10:09 PM
