Aerostar Ford Aerostar
power windows quit working
Old 02-16-2006, 09:25 PM
knabjordan's Avatar
knabjordan
knabjordan is offline
I have a ford aerostar (1990). The passenger window quit working, I'm sure it is the motor. Is there anyway to put the window up, to replace the motor?
Old 02-16-2006, 10:54 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old 02-16-2006, 10:58 PM
93nighthawk's Avatar
93nighthawk
93nighthawk is offline
Welcome!
I take it that you checked to see if the drivers window still works (if not blown fuse.)
Did you try the passenger switch to raise the window?
If that does not work, you have to remove the door panel and manually raise the window. It has been forever, but I believe that you can do it with a long screw driver.
Old 02-17-2006, 09:23 AM
knabjordan's Avatar
knabjordan
Thanks, do you know where to put the screwdriver? We tried that without luck. Drivers window works but both switchs for the passenger window don't. I know it's not the switches so I thinck it's the motor.
Old 02-17-2006, 02:17 PM
93nighthawk
I will go check my manual and see if I can get more descriptive on how too and post later. It has been forever sense I have had to manually roll up a window, normally there is a "bolt" that you screw to manually work the window.
Old 02-21-2006, 09:46 AM
vwhed1979's Avatar
vwhed1979
vwhed1979 is offline
Passenger window
My passenger window was stuck up when I bought my van. I checked all switches and fuses and wiring, all OK. I have an R/C truck, and 3 9.6V batteries for it. I wired two batteries in series, that when charged put out about 20V. Briefly hit that to the motor, and it went down. Now, it works normally, except sometimes I have to bump the switch a few times once in a while to unstick it from the seal. It is a little slow too, but works. Anyway, try applying a higher voltage to just the motor.
Old 02-21-2006, 02:06 PM
krankshaft's Avatar
krankshaft
krankshaft is offline
Vwhed:
If your window is sticking or moving slowly up the track just spray some silicone lube in the track that should loosen it up . I had a window that would move at all without help sprayed some lube in there and its been like new ever since.
Old 02-21-2006, 02:19 PM
copper_90680's Avatar
copper_90680
copper_90680 is offline
It's very strange, but I once probed the voltage applied to the motor on the passenger side. When you use the switch on the passenger's side, it applies a full 12.5V (battery voltage) to the motor. But if you use the master switch on the driver's side, you'll see only 11V (or thereabout) on the passenger side motor. That means the passenger window goes up faster if you use its own switch, but slower (and weaker) if you use the driver's switch.
I guess the guy who designs this system used to work for the IRS There must be a couple of diodes in the line acting the part of goverment waste.
Old 02-21-2006, 09:06 PM
vwhed1979's Avatar
vwhed1979
voltage drop
Thats interesting about the voltage from the driver switch, but my passenger switch is broken, so I cannot test it. I have to get some silicone spray. I need to do some suspension work, and get some of the squeaks out too.
Old 03-07-2006, 07:25 PM
Giznawz's Avatar
Giznawz
Giznawz is offline
Hello. I just wanted to put this thread back at the top as I have this same exact problem... Passenger window won't work with either passenger or driver side switch, driver's side window does work. Prior to passenger window failure, the window was going up and down slowly. The window is now stuck down. Did Nighthawk look into where to stick the screwdriver to manually raise the window?
Thanks,
Giz
Old 03-07-2006, 11:24 PM
93nighthawk
Sorry, I completely forgot about this thread. The next day I came down with the flu. I promise tomorrow I will take a look and post the results.
Giznawz, I would try lubing the guides with lithium spray, it is a common problem for those to dry out.
Old 03-07-2006, 11:48 PM
Giznawz's Avatar
Giznawz
Giznawz is offline
I pulled the window motor and the window switch/door lock wire harness. I think that my problem is that the up position in the window switch is bad. With the switch in the down position, 12v is delivered to the motor and the motor runs. With the switch in the up position, my voltmeter changes from 0.00v to -0.00v, and of course the motor does not run. Is there anyplace online which would sell a replacement switch?
As a side note, the window freely moves up and down with the motor removed. I will reinstall the motor with the window in the up position and the switch disconnected until I can get the switch replaced.
Thanks,
Giz
Old 03-07-2006, 11:50 PM
93nighthawk
NAPA Carries the switch (at least they use to) otherwise it is a Ford only item or the junkyard.
Old 03-10-2006, 06:37 PM
93nighthawk
Well I read through my chassis manual several times and they don't mention how to lower or raise a window.
I would try removing the interior pannel and see if you see the screw on the motor, if not, try jumping 12v to the motor to see if it works (First lube the channels.) and get it up enough to replace.
Old 03-11-2006, 12:53 AM
Giznawz's Avatar
Giznawz
Giznawz is offline
I was able to remove the motor with the window down. I had to drill 2-1/2" diameter holes to expose 2 of the 3 bolts holding the motor to the door frame. The third is already exposed through a 1/2" diameter hole. There are 2 dimples in the door panel where you should drill. With the bolts out, I used a small screwdriver through the bolt holes to push the motor towards the outside of the door, disengaging the gears. It dropped to the bottom of the door cavity, but no harm was done. Once the motor was out, the window moved freely up and down. I propped the window up and reinstalled the motor.
Jumping 12v to the motor would have been easier, but I assumed my motor was bad to begin with.
IHdieselfan
09-21-2018 11:20 AM
BocceMon
07-25-2016 01:57 PM
sealer700
1999 to 2016 Super Duty
05-01-2016 05:08 PM
bigguyinmo
02-05-2016 11:56 AM
cheetoh
05-26-2005 07:09 AM
Quick Reply: power windows quit working
