Power Window Mystery...
Old Jul 25, 2016 | 11:59 AM
BocceMon's Avatar
BocceMon
Can't figure this one out. My power window on the drivers side quit working. I was all set to take the door apart to investigate two days later and found that the window was again working just fine. This has happened three times now. When the window is inoperative I can hear the motor trying to activate. Any ideas what might be going on? Thanks in advance!
P.S. This window also often shudders when going up.
Old Jul 25, 2016 | 12:09 PM
FordTruckfan89's Avatar
FordTruckfan89
Felts may be shot, cheap and easy to replace.
Old Jul 25, 2016 | 12:13 PM
rla2005's Avatar
rla2005
Very common issue.......
a previous post:
The plastic spacers in the lift motor gear assembly are known to wear then cause this issue. Some info in this thread: https://www.ford-trucks.com/forums/98...or-repair.html
Old Jul 25, 2016 | 12:45 PM
BocceMon's Avatar
BocceMon
I had a brand new motor/regulator installed at a body shop this past winter. I'll crack it open and have a look see.
Old Jul 25, 2016 | 01:44 PM
Mike1's Avatar
Mike1
mine failed a few times too, but I found mine was a broken wire in the harness between the door ands the frame
Old Jul 25, 2016 | 01:57 PM
BocceMon's Avatar
BocceMon
Thank you guys! I'll post what I find and a resolution if any!
badaz4570's Avatar
badaz4570
One of mine had worn plastic spacers and the other was gunked up with old dirty grease.
Not hard to fix.
RenoHuskerDu
May 4, 2018 10:30 PM
Kelly Aitken
May 6, 2013 02:37 PM
oldhokie
Electrical Systems/Wiring
Jul 26, 2012 05:29 PM
tpd475
1997 - 2003 F150
Sep 13, 2006 12:47 AM
kilika77
1997 - 2003 F150
Nov 12, 2005 09:21 PM
