perches
09-29-2005, 08:38 PM
on
perches
I'm putting a 1976 351w into my 1986 f-150 that currently has a 300 6cyl.
Where can i buy 351w perches for my 86 4x4???
09-30-2005, 10:13 AM
I am under the impression that the I6 and the Windsor family of motors share the same perches. Now the mounts are probably different...
--Mike
09-30-2005, 11:19 AM
I6 and Windsor perches are different. Just get a set of 302 or 351w perches from a wrecker (from 80-96 truck) or parts supplier and you'll be all set.
09-30-2005, 12:14 PM
I6 and the "FE" motors use the same perches.
Also if you have a 4wd, then you need the correct perches from another 4wd.
2wd & 4wd perches are not interchangable.
09-30-2005, 03:45 PM
I believe in his 86 that 2wd and 4x4 perches would be the same, since both use the same frame in those years. 73-79 however, the perches are indeed different between 2wd and 4x4.
09-30-2005, 08:25 PM
on
The perches in my truck will not work with the 351w. Will napa or car quest have perches. Are there any online stores that have them?
Cliff
10-03-2005, 07:37 AM
Thanks loudfourds, learn something new all the time here.
Green Streak
Engine Swaps
09-23-2019 05:18 PM
77FordDW
Engine Swaps
11-11-2008 07:25 PM
86step
07-22-2008 03:26 AM
302 F-150
Engine Swaps
07-07-2008 06:02 AM
BarryMc
01-03-2008 01:32 PM
