perches for 351w
Old Jul 9, 2008 | 11:03 PM
86step's Avatar
86step
perches for 351w
Is there any auto parts store that carries engine perches? If not, is there any trick to getting the perch off? I would rather not spend hours drilling out those big rivet things holding on the drivers side perch.
Old Jul 9, 2008 | 11:07 PM
HighdefJoe's Avatar
HighdefJoe
I just made another post about perches! I don't think you can get the perches at a store. They have to be a boneyard special.... Do you have a picture of them that you could post for me please? Also, what tranny do you have?
Old Jul 9, 2008 | 11:36 PM
hoxiii's Avatar
hoxiii
LMC truck sells new V8 perches.
Justin
Old Jul 10, 2008 | 06:44 AM
fellro86's Avatar
fellro86
Grind the head off, then use a chisel to wedge in between the frame and the perch.
Old Jul 11, 2008 | 09:01 PM
86step's Avatar
86step
I just checked lmc. They want $180 for one. Guess I'll be grinding.
Old Jul 11, 2008 | 10:19 PM
Franklin2's Avatar
Franklin2
I find using a center punch, and then using a drill bit to get rid of most of the metal on the head of the rivet is fastest for me. With most of the metal drilled away, then the chisel works very fast.
Old Jul 21, 2008 | 12:27 PM
Boss50's Avatar
Boss50
I ordered mine from a Ford dealer. $70 a piece roughly
Old Jul 21, 2008 | 12:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1981/96 F100/350 & Bronco 302/351W engine supports.
You ordered 302/351W engine mount supports from a dealer for $70.00 each? (302/351W's use the same ones).
You got a deal on the left side.
EOTZ6028d .. Right Engine Support-302/351W (aka tower, bracket, stand, perch) EOTZ6028d (**) replaced EOTZ6028C
MSRP: $72.38 / FTEpartsguy.com price: $52.12
EOTZ6029D .. Left Engine Support-302/351W (aka tower, bracket, stand, perch) EOTZ6029D replaced EOTZ6029C
MSRP: $149.33 / FTEpartsguy.com price: $107.52
Fit: 1981/89 F100/350's & Bronco's / 1990/96 F150/350's & Bronco's.
** Why the small d after 6028?
On FTE you cannot type the number 8 followed by the capital letter of D without getting this:
Old Jul 21, 2008 | 08:00 PM
ctubutis's Avatar
ctubutis
On FTE you cannot type the number 8 followed by the capital letter of D without getting this: 8D
Ah, but I think you can... check the box at the very bottom that says:
Disable smilies in text
-ct
8D 8D 8D 8D 8D ;-)
Old Jul 22, 2008 | 03:26 AM
NumberDummy
Learn sumptin' new everyday...thanks.
Vampiro
Feb 26, 2017 12:51 AM
ffjoey
Feb 2, 2016 12:46 PM
Xcr600man
Jan 11, 2016 03:58 PM
torquemeister
Engine Swaps
Jan 23, 2010 01:20 PM
T-Bird Stu
Jun 26, 2003 09:32 AM
