2001 Ranger Air Bag Code 29
Old 09-17-2005, 01:51 PM
REPORANGER's Avatar
REPORANGER
REPORANGER is offline
Anyone have any idea what airbag code 29 on a 2001 ranger means? I have not seen that number on any code lists. I triple checked the code and it is 29.
Thanks, Reporanger
Old 09-17-2005, 03:45 PM
Dave257's Avatar
Dave257
Dave257 is offline
I don't have that code listed in any of my ford books. ?? It may be an undocumented code, can you give a little history on the truck? Does the A/B light stay on after it counts and how many times does it flash the code.
Dave
Old 09-17-2005, 07:37 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Airbag Code 29 - Incorrect Vehicle Identification Code
Welcome to FTE! I could only find an Airbag Code 29 in the ‘00 Manual:
Code 29 = “Incorrect Vehicle Identification Code”
“The restraints control module (RCM) monitors the voltage at pins 10, 13 and 14 to determine if it is installed on the correct vehicle. If the RCM detects an incorrect voltage on any of these pins, it will store a diagnostic trouble code (DTC) C1414 in memory and flash a lamp fault code (LFC) 29 (or higher priority code if one exists) on the air bag indicator.
An incorrect vehicle identification 29/C1414 code could be caused by:
- an RCM installed on the wrong vehicle.
- an incorrectly programmed RCM.
- vehicle ID pins not connected as expected.
The RCM is located behind the center of the dash. You'll have to remove the beverage/utility tray (if so equipped) to get at it.
WARNING: To avoid accidental deployment and possible personal injury, the backup power supply must be depleted before repairing or replacing any front or side air bag supplemental restraint system (SRS) components and before servicing, replacing, adjusting or striking components near the front or side air bag sensors, such as doors, instrument panel, console, door latches, strikers, seats and hood latches.
To deplete the backup power supply energy, disconnect the battery ground cable and wait at least one minute. Be sure to disconnect auxiliary batteries and power supplies (if equipped).
Old 09-17-2005, 09:46 PM
REPORANGER's Avatar
REPORANGER
Rockledge, Thanks for the deciphering the code. And Dave257 thanks for the response.
When I purchased my Ranger I didn't know the driver's bag was blown. The kid who had it…covered the blown airbag with tweed. I replaced the bag with another from a 2001 ranger only to find that the RCM was missing as well as the airbag switch and the light in the gauge cluster. I replaced all components with used parts. The RCM was out of a 2000 ranger that had not been in an accident. It seemed to matched the original in all aspects. All I had to do was plug it in. Do you think I need another RCM from a 2001 or can the RCM I have be cleared? Any additional input would be greatly appreciated.
Thanks!
Old 09-18-2005, 09:08 AM
Rockledge's Avatar
Rockledge
You can try the pinpoint tests for Code 29 to the extent you are able and see what happens. Otherwise, it sounds like it might be something to talk to the dealer about, to try and at least find out what it takes to ensure RCM "compatibility":
PINPOINT TEST E: AIR BAG LAMP FAUT CODE 29/DTC C1414 — INCORRECT VEHICLE IDENTIFICATION CODE
E1 CHECK FOR A HARD OR INTERMITTENT DTC
- Retrieve/Clear Continuous DTCs
- Was DTC C1414 retrieved during the on-demand self test?
Yes
This is a hard fault. The fault condition is still present. This fault cannot be cleared until it is corrected and the DTC is no longer retrieved during the on-demand self test. GO to E2 .
No
This is an intermittent fault. The fault condition is not present at this time. GO to E4 .
E2 CHECK THE VEHICLE IDENTIFICATION PINS NO. 2 AND NO. 3
NOTE: For this vehicle application, RCM pins 13 and 14 should be open circuited.
- Make sure the RCM pin 13 and pin 14 connector slots are empty and no connection is made when connected to the RCM.
- Are the RCM pin 13 and pin 14 connector slots empty?
Yes
GO to E3 .
No
REPAIR any concern found at the RCM pin 13 and pin 14 connector slots. GO to E3 .
E3 CHECK THE VEHICLE IDENTIFICATION PIN NO. 1
NOTE: For this vehicle application, RCM pin 10, circuit 57 (BK) should be connected to ground.
- Measure the resistance between RCM pin 10, circuit 57 (BK), harness side and RCM pin 21, circuit 649 (BK/OG), harness side.
- Is the resistance greater than 100 ohms?
Yes
REPAIR the circuit. GO to E5 .
No
GO to E4 .
E4 CHECK THE RCM PROGRAMMED VEHICLE ID
- PID/Data Monitor and Record
- Select PID VID#1, VID#2, VID#3.
- Was vehicle ID #1 Ground, vehicle ID #2 No Connect and vehicle ID #3 No Connect?
Yes
GO to E5 .
No
INSTALL a new RCM. GO to E6 .
E5 CHECK FOR AN INTERMITTENT FAULT
- Was the continuous DTC retrieved during Step E1 an intermittent fault or were you directed to this step from Step E3?
Yes
CHECK for causes of an intermittent open on circuit 57 (BK). Attempt to recreate the hard fault by flexing the wire harness and cycling the ignition key frequently. REPAIR any intermittent concerns found. GO to E6 .
No
GO to E6 .
E6 CHECK FOR ADDITIONAL DTCs
WARNING: The restraint system diagnostic tool is for restraint system service only. Remove from vehicle prior to road use. Failure to remove could result in injury and possible violation of vehicle safety standards.
- Were any continuous DTCs retrieved during Step E1?
Yes
Do not clear any DTCs until all DTCs have been resolved. GO to the Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Priority Table in this section for pinpoint test direction.
No
RECONNECT the system. PROVE OUT the system. CLEAR all DTCs.
Old 09-18-2005, 11:50 AM
Dave257's Avatar
Dave257
Dave257 is offline
Since that code dosen't seem to be used in the 01 rangers I suspect you have a different "box" then you need. Since it was in a wreck I would do the pinpoint tests as suggested by Rockledge.
Dave
Old 05-14-2012, 06:55 PM
DLeach4512's Avatar
DLeach4512
DLeach4512 is offline
'02 Ranger Code 29 help?
So i've read through the thread here, but I don't think i'm seeing anything useful.
I've got an '02 4.0 4x4 4D Ranger that's never had the airbags deployed, and never had the RCM replaced, or AFAIK, touched. I'm the second owner, and the first one only did routine/needed maintenance, with records.
I've had some battery issues lately (the DLG started to die; sometimes it would hold a charge, sometimes it wouldn't), and two days ago my AB light came on. I learned here that it flashes a code, so I paid attention and got code 29.
I checked the connections under both seats, and at the key-turn for the PSAB, and I don't see anything wrong/broken/unusual/disconnected.
Any ideas of what to try next?
Old 08-05-2012, 11:01 AM
emsmarkv's Avatar
emsmarkv
emsmarkv is offline
Air bag code 29 on 2002 ford ranger
Ok so here is what I experienced:
Disconected the battery for some routine repairs, did a r&r fuel pump and u-joints, cleaned battery posts. Went for a test drive: had no speedo or interior lights and air bag flashed code 29 (oh, crap). The next day also found no wipers (Could be an RCM, GEM or BCM... OH CRAP!!). Could not see a blown fuse but tested them with a light and found a 10 amp position 26 fuse blown. Put in a new one and on the road again! There are as many as 10 or 12 different fuses, relays or diodes to check related to this issue; start with the easy one in the interior fuse panel. Great times!
Since Fords run together, if you have a 2xxcould start with prior years also) Tuarus and are doing the inner tierod ends get the Lisle 45750 Tool. Few other things will fit the Ford original tierod.
Old 03-29-2016, 02:03 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Had the same issue as the above poster on my 2003 Ranger. No dome light, no speedometer or odometer, and airbag flashing code 29. Didn't check the wipers. Pulled the position 26 (10 amp) fuse and sure enough, it was blown. Replaced it and immediately heard the battery saver relay click and that fixed all three issues.
Old 08-15-2016, 07:56 PM
colemanfuel's Avatar
colemanfuel
colemanfuel is offline
99 Ranger Sport (Automatic) code 29
I had the code 29 issue with my 99 Ranger 3.0L automatic. Found the RCM under the console/cup holder. To clear the code, all I had to do was unplug the RCM a few seconds, then plug it back in. Easy as pie!
Old 09-18-2019, 06:20 PM
Josh25614's Avatar
Josh25614
Josh25614 is offline
Had the same issue last night. Fuse 26 (15 amp) but im not too sure if that was the right amp fuse to begin with, was blown. I replaced with the closest spare i had as a temp solution, all i had was a 25 amp. Is that a too high?
Old 09-19-2019, 08:28 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Welcome to FTE Josh.
Electrical circuits are fused to protect from damage, so it's not a good idea for us to Over fuse, or use the wrong Type fuse, (as in using a slow blow Type with a heat sink that allows for a brief Spike overload, that's for motor containing circuits that have a large current spike when starting, but shouldn't be used for sensitive solid state circuits that don't like current spikes), as if there is still a over current condition, the Over fusing, or wrong Type fuse of a conductor, component, or circuit, not rated to take the 25 amps you've fused for, can cause serious damage to other things in the circuit, or even a fire from overheating.
We don't know what year/model your ride is, so If you'll look on the fuse panel board, cover, or in your owner or repair manual, it'll usually have the correct amp & type fuse or circuit breaker specified, so to be safe we should use only what the circuit designer specified.
If you don't have fuse covers with the info, or a owner manual, one can be down loaded at no cost here. https://www.fleet.ford.com/partsands...owner-manuals/
Some general fuse / circuit breaker thoughts for consideration, hopefully the over current condition had cleared & you haven't fried the circuit by grossly over fusing it, so let us know how it goes.
cinderblock
17
12-09-2020 12:04 AM
Tsandnc
06-27-2017 04:20 PM
Whitetail90
17
03-11-2017 07:37 AM
billmuir
12-05-2016 01:59 PM
DLP Performance
03-06-2016 07:07 AM
Quick Reply: 2001 Ranger Air Bag Code 29
