'79 F-250 transfer case
11-11-2002, 11:34 AM
on
My dad has a '79 F-250 4x4 with a part time transfer case.
I don't know which lever position is which. I believe that all the way forward is 4x4 low, next back is nuatral, then 2x, then 4 Hi (all the way back). Is this correct?
11-11-2002, 01:16 PM
on
To make it a little clearer, this is the way it would look, from what I can figure out:
4x4 low
N
2x
4x4 high
Is that correct, or did I get it wrong?
11-11-2002, 03:02 PM
all the way back keeps it in 4wd all the time. up one it is in 4wd until you hit 35 mph i think
11-12-2002, 01:44 AM
on
does it have manual locking hubs?? if so you are correct on the shift pattern!!!!
neal
78 f250 400,np435,np205,dana60s front and rear,4.10gears
11-12-2002, 12:25 PM
your exactly right shec
11-12-2002, 02:01 PM
Being that you say it's a part-time, I'd say it's an NP205. An easy way to tell is to look at it. If it cast iron, and kinda boomerang shaped, it is a 205. If it is aluminum, and an elongated oval shape, it's a 203. Also, it should have a tag either on the rear of the case, between the drain and fill plugs, or on the front above the front driveshaft.
Jared
11-12-2002, 03:42 PM
on
[updated:LAST EDITED ON 12-Nov-02 AT 04:42 PM (EST)]The truck has manual hubs.
I wrote down the transfer case model in the repair manual, but it is at my dad's ranch and I don't have access to it or the truck at the moment.
P.S., thanks for the replies.
11-12-2002, 04:09 PM
my bad i somehow got the idea that it was a full time t-case
11-12-2002, 04:12 PM
There is a part on e-bay right now for that.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1872450150
11-13-2002, 09:50 AM
on
11-13-2002, 03:52 PM
on
shec i right
got one of those t cases myself
BORDERBUM
04-10-2016 02:36 PM
Gear619
02-23-2015 11:06 PM
SDBASS-F150
04-18-2006 08:08 PM
Fat&Bald
04-15-2004 10:59 PM
larbuck
11-29-2001 01:08 PM
