I anybody else having trouble with the rubber valve stems on their DRW Aluminum rims. I have lost 3 the third one today on the way back from camping plus this is the second time I have ruined a tire. The stem split at the base of the stem I'm not sure if the wheel is cutting them or just bad stems.
I had the same problem on my class C E350. The previous owner had put new tires on it and the tire place did not install the high pressure valve stems.
You most likely have a standard pressure valve stem on your tires. and it will not handle the 60-80 psi you put in the tires.
The stems that are going bad are the ones that came with the truck when new, I am replacing all 4 back tires and stems (metal) and braking down the front ones and replacing the stems with metal also.
