Why 2 catilytic convertors?
Old 06-14-2005, 12:36 AM
coplin's Avatar
coplin
coplin is offline
truck in my signature 1988 F-150 351W.
Just after the Y in the exhaust system is the first CAT I'm told. Then further downstream is the second one. I thought the first one was actually a resonator, but apparently they are both Cats , is this correct?
Where I live Im subject to emissions. My exhaust is new starting from behind the first cat? back downstream. The original second Cat was replaced with a new hi-flow unit.
So is the first upstream unit a CAT or Resonator ?
If its just a Resonator what effect will it have if I cut that out of the system and replace with exhaust pipe?
If it IS a CAT can it be replaced with the same 3-way hi flow CAT I replaced the other one with?
Old 06-14-2005, 01:38 AM
MemOrex's Avatar
MemOrex
MemOrex is offline
The first one is the pre-heater cat. The second one is the one that does most of the work. I replaced both of them with pipe. The first one was a pain since it was dual in. Look at my gallery. Im gonna order a hi-flow one off ebay soon.
I dont know if you can replace that first one...you gotta look for a dual in cat or something.
Old 06-14-2005, 03:01 AM
coplin's Avatar
coplin
coplin is offline
What makes the first one dual in? is that one with the tube from the EGR.?
Old 06-14-2005, 03:27 AM
coplin's Avatar
coplin
coplin is offline
Actually I found this link.: http://www.car-sound.com/catalog/universal/940.aspx
Since I have annual emissions testing in my area I'm not going to take a chance removing the first one even though it supposedly only reduces emissions at startup phase.. They have the dual in CAT that you mentioned too.
sidewinder770
Modular V10 (6.8l)
09-12-2014 05:39 PM
granny_rocket
21
04-21-2010 09:32 PM
RangerPilot
1983 - 2012 Ranger & B-Series
20
10-20-2006 09:39 PM
mightypan42
Exhaust Systems
12-02-2005 10:16 AM
ceetwarrior
28
07-26-2005 08:47 AM
Quick Reply: Why 2 catilytic convertors?
