HF 20 Ton Shop Press??
I have been watching these presses for a while and last week I got a flyer with them listed for $169, that's about as low as I've ever seen them. Anybody own one? I have about a gazillion u-joints to do and I would like to fab up a bender so I think I might pick one up this week...
I also have one, and have used it a couple times to press out motor mounts on my Jetta and a few other things. Occasionally when I lift the handle to pump it, it will want to snap back down, almost like it didn't suck any fluid that stroke. I figure its a valve in the jack sticking a bit, usually clears up after the first few strokes. It was definitely worth the money.
I built a better base for mine from U channel; same dimension as the press uprights. Got rid of the small angle iron feet. Also made many adapters for the ram from old sockets and extensions. Various plates also augment the pair you get with press. It has worked well for a year and I have removed and replaced bearings and ball joints. Mine was $179 and had a $20 off coupon to make it $159 but that was a year ago. Painter's Touch "Real Orange" Spray from Walmart was a good match for HF orange.
Came across HF press on Craig's list and decided to hold off, agree the frame did not appear that strong. Happened upon 20 t on Craig's list week later, much better quality and oh what a deal, the extra plates thrown in were worth the price alone. Put wheels on it and able to move it around. Don't use that often but certainly comes in handy when I do. Fellow backyard mechanics in the area drop in on occasion to use it.
GuitarJesus
02-26-2015 08:08 PM
queen of spades
General Automotive Discussion
10-18-2013 09:53 PM
SoArkSI
09-29-2007 11:39 AM
