Pressing U Joints, Problems
Old Feb 25, 2011 | 02:22 PM
Immortal_Ben's Avatar
Immortal_Ben
I have a 12 ton shop press, and am trying to press out a u joint from my axle shaft. The cap pressed a little bit, but stopped, and I have bent the ear of the shaft a little bit.
Started pressing the next side of the u joint and it also pressed a little bit and stopped.
Am now worried about bending another ear. What the heck is going on? Any tips, suggestions?
Yes, I took out the retaining clips on all sides.
Old Feb 25, 2011 | 04:49 PM
Paultv's Avatar
Paultv
If you have access to a cutting torch heat always breaks it loose ,if you don't try Mapp gas in the yellow bottle it burns hotter than propane the blue bottle
Old Feb 25, 2011 | 06:18 PM
EXv10's Avatar
EXv10
You might have had it at an angle which put it into a bind. It probably went far enough to take up the airspace before trying to push the other cap out. Make sure it is all level and right before pressing. It might be in a bad bind now though because it takes a lot to bend the shaft. Heat is the only possible saviour now.......or a new shaft.
Old Feb 25, 2011 | 09:11 PM
Immortal_Ben
thanks for the responses guys. through the amazing capabilities of the ingenious redneck mind, i not only got the u-joint out, but have nearly finished bending the ear back into place. the tool that got me over the top..... vice grips! anywhoo should be able to finish up the project tomorrow. new needle bearings, hub servicing, and axle shaft u-joints. got that new press today too... was a good day indeed.
Old Feb 26, 2011 | 11:35 AM
EXv10's Avatar
EXv10
We didn't know you got to the point where the cap was exposed. I usually use vice grips at that point.
Blue and White
Oct 24, 2013 08:24 PM
SLUF681
Mar 22, 2011 04:39 PM
mechelement
13
Oct 1, 2010 06:50 AM
rallyracer
Aug 12, 2010 09:59 AM
mechelement
Oct 12, 2009 01:26 AM
