General Automotive Discussion
Old 11-17-2014, 06:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Motorcraft vs. Autolite spark plugs
Old 02-14-2005, 10:43 AM
88n94's Avatar
88n94
88n94 is offline
It is fairly common knowledge that Motorcraft spark plugs are made by Autolite. Is a plain old Autolite spark plug just as good as a Motorcraft, or does Ford require Autolite to manufacture the motorcraft plugs to a different specification. I hear all kinds of comments on this from just use the much more inexpensive Autolite because Autolite makes Motorcraft to Autolites are junk use Motorcraft.(the latter may not know Autolite makes Motorcraft). Again I am wondering if Autolite and Motorcraft are of the same quality or if Motorcrafts are manufactured to a different specification. Thanks in advance for any replies.
Old 02-14-2005, 11:48 AM
Bruker's Avatar
Bruker
Bruker is offline
I've always considered them to be the same.
Old 02-14-2005, 12:35 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
I think that Honeywell makes spark plugs for both Motorcraft and Autolite, and that almost all Autolite plugs are made to the same specifications as their Motorcraft counterparts. It would not surprise me if these "sister" plugs are even pulled off the same assembly line. So I think we can say they are for the most part identical.
HOWEVER, there is a caveat to this. It should be noted that Honeywell does NOT make EVERY plug for Motorcraft, and so it's possible that another company could be a source of a particular Motorcraft plug. For example, the recommended OEM replacment plug for my Taurus SHO's 3.0L DOHC engine is Motorcraft's AGSP32PP which is made by Denso, not Honeywell. Nonetheless, there is an Autolite plug (APP3924) made by Honeywell that purports to be the OEM equivalent of the AGSP32PP, but they aren't really the same (among other things, the APP3924 is a little bit longer than the AGSP32PP). The Autolites work fine in the SHO but the plug wires tend to fit a little differently on them which makes some SHO owners a little uncomfortable (not me...I run Autolite DPs in all my vehicles). Bottom line is that the recommended Motorcraft plug and the recommended Autolite plug are not always the same animal. It all depends on the application.
Old 02-14-2005, 01:21 PM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
I've always used either Autolites or Motorcrafts as of late. I've never had troubles with either and have always worked good in my Ford vehicles.
Awhile back I fell for the Bosch +4's but I got burned on that deal.
Old 02-14-2005, 06:41 PM
captchas's Avatar
captchas
captchas is offline
Guest
way back ford owned the autolite name. now its allied signal company .both brands look alike except for the label painted on the plug. all i know for a fact is every one of my cars, trucks and boats run great with them. superrangerman i see the same thing every day some cars they run great some they don't and vw is one of them that they don't
Old 02-14-2005, 07:34 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
A while back I emailed Honeywell and asked them about their spark plugs. This is the reply I got.......
"As a division of the Honeywell Corporation, Autolite is the manufacturer responsible for the production of all Motorcraft spark plugs in North America for the Ford Motor Company. Both Autolite and Ford/Motorcraft spark plugs are built to quality standards using quality components. Autolite manufacture's the Motorcraft plugs based on the specific design requirements of the Ford Motor Company. Autolite and Motorcraft spark plugs are manufactured side-by-side at our facility in Northern Ohio."
Note that it says they build the Motorcraft plugs based on specific design requirements of the Ford Motor Company.
I still don't like Autolite plugs as I've seen lots of them fail.
Old 02-14-2005, 07:44 PM
V10KLZZ71S's Avatar
V10KLZZ71S
V10KLZZ71S is offline
Dave i was a little surprised about the Autolite failures.I know for yrs most top fuel teams and a lot of other racers even gm used Autolite.Dont know what the Nitro cars use now though.Now Champion plugs I have seen many failures.I had a 25 mercury that absolutly would not run for long w/champions.
Old 02-14-2005, 08:31 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
I suppose it's like most things. Some people swear by Champion spark plugs, some people swear at them. Same as Bosch, Autolite, NGK or whatever.
Old 02-14-2005, 08:34 PM
Rockledge's Avatar
Rockledge
I'm surprised by that, too. But I notice in the email Dave got back from Honeywell that nowhere do they claim that the Autolite plugs are manufactured to Ford specs. Hmmm....
The following users liked this post:
Old 05-11-2008, 09:45 AM
HARALSON COUNTY's Avatar
HARALSON COUNTY
HARALSON COUNTY is offline
Spark Plug Repalcement 02 F150 4.6
SINCE THERE ARE SOME VERY SMART PEOPLE ON THIS POST I THOUGHT I WOULD ASK THIS QUESTION.
wHAT IS THE EASIEST WAY TO GET THE BACK 2 PLUGS OUT ON THE DRIVER SIDE AND THE LAST PLUG ON PASENGER SIDE ON 02 4.6 F150
I HAVE NOT CHANGED ANY PLUGS IN A VERY LONG TIME LAST WAS A 1985 150 AND 91 LTD.
THANKS
Old 05-11-2008, 11:20 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Welcome to the forum Haralson County
For some tips on replacing your spark plugs tke a look at https://www.ford-trucks.com/forums/1...ark-plugs.html
Old 05-11-2008, 05:12 PM
HARALSON COUNTY
Plug Replace
Ok I Get The Pic. On 5 Of The Plugs Put Do I Need To Remove The Fuel Rail For The Back Two On Drivers Side They Aint Much Room
Thanks For The Help
Old 05-11-2008, 10:48 PM
BLK94F150's Avatar
BLK94F150
BLK94F150 is offline
I had an Autolite plug self destruct in the #1 cylinder of my 2000 F150. I have no idea how it didn't take out a valve. The center electrode and grounding strap were completely gone.
Needless to say, they are all Motorcraft now.
Mike
Old 05-12-2008, 12:17 PM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
Ive seen regular Motorcraft plugs last almost 100,000 miles on the 4.0 engine and the Autolite Platinum replacements worn out at 40,000. Quality is NOT the same, not even close. I tend to go with the exact OE plug, if available.
Jim
Old 05-12-2008, 02:32 PM
spikedog's Avatar
spikedog
spikedog is offline
For the amount of labor it takes to put them in, the plugs aren't that expensive. Especially on some of today's rigs - the plugs are a PITA to get to. Save a buck, but lose some peace of mind. I'd agree with you, Jim, OEM plugs are the way to go.
Quick Reply: Motorcraft vs. Autolite spark plugs
