Dash Pad Removal 97 F350
Old 02-02-2005, 10:44 PM
fordv840's Avatar
fordv840
fordv840 is offline
Hey all,
I have a 97 F350 OBS and I would like to replace the dash pad above the glove box that also goes over the radio (mine's cracked). Anyone know how this comes off? Also anyone know if you can get this from Ford or a parts dealer? Most of the ones in the junkyard are also cracked.
Thanks,
Jay
Old 02-02-2005, 10:53 PM
sixstick94's Avatar
sixstick94
sixstick94 is offline
can't help with locating one, but I can tell you how to remove it, I just did this in my '94 F-150
1)you will have to remove the radio and drop the glove box
2) Ford put studs in the pad and held them on with 10mm nuts inside the dash
3) Remove these nuts, there should be about nine of them, with 3 or 4 surrounding the radio.
4) Pad should lift out, if not, check for another nut, all these can be removed using a combination of 10mm wrench and 10mm socket, preferably 1/4" drive. Space is tight but it still only took me 15 minutes to R&R.
Old 02-02-2005, 10:58 PM
fordv840's Avatar
fordv840
fordv840 is offline
Cool thanks, I am putting an aftermaket deck in this weekend so maybe I will do both at the same time if I can find a good pad!
Old 02-03-2005, 08:30 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
maybe you should post this in the 97 and up section.
Old 02-03-2005, 09:32 PM
mac95150's Avatar
mac95150
mac95150 is offline
I think that he is talking about the old body style f350 92-97 model. I also had a hard time finding one in a junkyard but I finnaly found on that wasnt cracked and I just remove the 10 (i think) 10mm bolts under the dash
Old 02-03-2005, 10:38 PM
fordv840's Avatar
fordv840
fordv840 is offline
I was referring to the old body style, that is why I posted it to this forum, I figured these guys would know best. My truck is a 97 but I guess the one tons carried over the same body style.
fordka
Ford Truck Parts for Sale
03-02-2017 05:10 AM
maytag906
07-12-2016 06:21 PM
GeneGregory
15
10-26-2015 06:17 PM
MEDF150
11-04-2009 12:42 PM
FESuperDuty
24
04-26-2009 02:48 PM
Quick Reply: Dash Pad Removal 97 F350
