Dual exhaust for an 82 F250???
Originally Posted by gus3333333333333333
Does anybody know of a bolt-on aftermarket dual exhaust for an 82 F250 4wd with a 351w?
you truck probably has a 351M not a W. On my '85 f250 with a 351W, I swapped on '87+ manifolds and the '87+ y-pipe (2 1/4").
I also have an 82 F-250 extended cab 4x4 powered by a 351W. I have not found any aftermarket bolt on dual exhaust kits. You can get headers, but the flange on the collector will rub on the front driveshaft. Not really a big deal, you can have the flange cut off and weld the exhaust pipe right to the collector. Go to any muffler shop, and they can fabricate a set up for you.
Well a dierect bolt on would be very hard to come across, I havent seen any and yes Ive looked. I know summit and jegs sell a universal dual system for cars and trucks with headders but ford kinda make it tricky to get over or under the xmember without a few custom bends. I'd suggest you find yourself a small muffler shop and have them setup your system.
Why run shorties, when you can go full length. When I bought the truck it had full length headers on it. The flange had rubbed on the front driveshaft for years before I owned the truck. It is not a big deal, nothing happened to the driveshaft. But, like I said, you can cut the flange off and weld the exhaust to the collector.
jwf1999
07-01-2004 08:29 AM
