'74 tank switch whats what?
Tank Switch :
The tank switch on a '74 only read the signal from the sending unit in the tank
to tell you the fuel level , actually I think it only read the ground wires of each .
The tanks were switched wit a valve which you turned manually and the engine fuel pump simply pumped from the other tank .
Maybe I got cheated, but when I ordered my '74 . . .
Hi-Boy brand spanking new with aux tank, it came with a single double-pole switch that was mounted under the dash and to the left of the steering wheel. That switch controlled both the tank signal and activated a solenoid valve when "hot" to connect the aux tank. I suppose it's possible that the 4x4's got different treatment than the 2xs, but would be surprised.
I have since upgraded to the switch incorporated into the later model heater controls module, and it connected the same way.
JFWIW. Steve
JFWIW. Steve
thetmaxx
08-03-2009 11:59 PM
fin1
1999 to 2016 Super Duty
01-22-2008 11:48 AM
