Unknown Switch
Old Aug 27, 2014 | 11:10 PM
WingingIt74's Avatar
WingingIt74
Unknown Switch
What does the switch under the starter button do?
Old Aug 27, 2014 | 11:16 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Remind me again. What year is your truck?
Ah, I see it's a 50. There is no switch under the starter button unless someone added one there.
Old Aug 28, 2014 | 12:53 AM
52 Merc's Avatar
52 Merc
Au contraire kind sir. On the early Bonus Builts, and earlier Fords, there was a toggle switch which operated the dash lights.
Old Aug 28, 2014 | 01:56 AM
Bluey Zedoff's Avatar
Bluey Zedoff
I am guessing the switch under the starter button is a starter switch to start the start button...but I could be wrong.
Heheh.
Old Aug 28, 2014 | 05:46 AM
fordf348's Avatar
fordf348
Most definitely the switch controls the dash lights
Ed
Old Aug 28, 2014 | 07:16 AM
WingingIt74
So the switch is for the dash lights... good to know... dash lights must be burned out.
How does the switch work, is it the only way to power the dash lights or is it a secondary switch to the headlight switch?
Old Aug 28, 2014 | 07:19 AM
mtflat's Avatar
mtflat
Secondary - the parking/running lights have to be pulled on. It just allows you to turn the dash lights off for night-time driving.
Old Aug 28, 2014 | 08:24 AM
abe's Avatar
abe
m not an expert on 48-50 trucks but if your dash lights are not working it is probably the rheostat is burned up in your light switch. Get a new light switch.
FortyNiner's Avatar
FortyNiner
Gentle suggestion: the Shop Manual is a great resource for wiring diagrams.
Old Aug 28, 2014 | 08:28 AM
WingingIt74
I know, I just haven't bought one yet. I have one for everything else I own.
Old Aug 28, 2014 | 08:29 AM
WingingIt74
I would bet money that the bulbs in the dash are still 6V and had not been switched over to 12V many years ago....
Old Aug 28, 2014 | 10:23 AM
WingingIt74
Ok onto the aftermarket plastic switch. It has two lime green wires that run to two terminals on the flasher, I can't see why and it doesn't seem to do anything.
Old Aug 28, 2014 | 10:25 AM
WingingIt74
I wouldn't think there is a rheostat in that little switch, it's a pretty small switch.
Old Aug 28, 2014 | 11:47 AM
dmack91's Avatar
dmack91
Just a WAG, but that switch looks like an afterthought to me. My guess is that, with the flasher installed, it was either a poorman's turn signal switch or hazard switch. If you can, trace the wires and see where they lead.
Old Aug 28, 2014 | 11:55 AM
WingingIt74
The thing is, it has hazards on the column, which work. Just from the flasher to the switch, both wires.
