'74 tank switch whats what?
Old 10-23-2004, 08:12 PM
ejustin3724's Avatar
ejustin3724
ejustin3724 is offline
The tank switch, was it all electric in '74 or electric switch for gadge and manual with a valve? I have the latter
Old 10-23-2004, 09:11 PM
Jerry Gougeon's Avatar
Jerry Gougeon
Jerry Gougeon is offline
Tank Switch :
The tank switch on a '74 only read the signal from the sending unit in the tank
to tell you the fuel level , actually I think it only read the ground wires of each .
The tanks were switched wit a valve which you turned manually and the engine fuel pump simply pumped from the other tank .
Old 10-23-2004, 10:16 PM
kermit's Avatar
kermit
kermit is offline
i thought that i had seen the electric wiring for the switching solenoid on the frame of my '73, but maybe not. i will have to look and see what is hanging there
Old 10-23-2004, 10:31 PM
ejustin3724
Thats what it is so(now)......that is what it was(in '74).....and thats what it will be. Oh thats what it looks like.
Old 10-26-2004, 06:52 PM
kermit's Avatar
kermit
kermit is offline
i wish someone with some knowledge could look at this thread and let us know if these valves were aftermarket throw ins when the frame solenoid went, or if the switch is purely for the guages
Old 10-26-2004, 11:07 PM
stephenw's Avatar
stephenw
stephenw is offline
Maybe I got cheated, but when I ordered my '74 . . .
Hi-Boy brand spanking new with aux tank, it came with a single double-pole switch that was mounted under the dash and to the left of the steering wheel. That switch controlled both the tank signal and activated a solenoid valve when "hot" to connect the aux tank. I suppose it's possible that the 4x4's got different treatment than the 2xs, but would be surprised.
I have since upgraded to the switch incorporated into the later model heater controls module, and it connected the same way.
JFWIW. Steve
Old 10-27-2004, 01:03 PM
kermit's Avatar
kermit
kermit is offline
maybe it was dealer installed?
WingingIt74
21
08-28-2014 08:21 PM
currituckF150
12-08-2009 10:49 AM
thetmaxx
08-03-2009 11:59 PM
fin1
1999 to 2016 Super Duty
01-22-2008 11:48 AM
Quick Reply: '74 tank switch whats what?
