Where is the O2 sensor located on 460?
89 F250, with 7.5L engine.
Okay, I know it is on the exhaust manifold. But I just cannot find it. I looked at both sides, and from the bottom, as well as from the top. Haynes/Chilton's are ambiguous and the FSM doesn't say which side, seems to vary based on the engine.
You don't need that special socket taking it out --- you can cut the wire and use a regular deep 7/8" socket. But it looks to me like based on location of this O2, I will have to use that special socket putting it in. Maybe I can get away with using a bent open end wrench.
I would rarther not, as it is a single-purpose tool, useless for anyting else.
On my 96 I replaced the O2 sensor without the use of any special tools. If I remeber correctly I just used an box wrench to remove it after I cut the wires for the sensor. To install it just use the open ended side of the wrench after getting it in finger tight. Some anti-seize helps on the install. It has been awhile since I did this so the above procedure may not be exatly correct but I don't have any special tool, of that I am certain.
Outlaw56
02-23-2017 07:58 PM
skooterkool
08-20-2016 10:54 PM
vrinner
01-23-2016 07:09 PM
bigtexan99
05-16-2011 02:41 PM
