How to tell the differnts between a 292 & a 312 ?
Old 01-09-2004, 11:02 PM
Customcab's Avatar
Customcab
Customcab is offline
Question How to tell the differnts between a 292 & a 312 ?
I recently purchase a 59 F100; could anyone help me ID the difference between a 292 & a 312? I was told a 292 has the distributor behind the intake and the 312 in front, the truck originailly had a 223 cid, so VIN# don't help.
Old 01-10-2004, 09:51 AM
65f100xmas's Avatar
65f100xmas
65f100xmas is offline
I can tell you this the 312 has the dist in the same place as the 292 there the same engine diffrent bore stroke there is a slite deck hieght on the block the way to tell if its either is does it look like a Y it really does the the intake sits up in th air a bit has a valley cover underneath it
Old 01-10-2004, 10:56 AM
FordBoypete's Avatar
FordBoypete
FordBoypete is offline
CC
He's 100% correct if it is a Y Block, 239 , 272 292 or 312 ( which about covers all "Y" Blocks) distribuitor is up front, like all were.
If it's a truck 312 CID it will have "ECZ-C" heads, And Big FAT tubular Pushrods like the 300Hp 312 w. a Paxton had.
FBp
Old 01-12-2004, 07:37 PM
Customcab's Avatar
Customcab
Thanks for the replies and help 65F100xmas & FORDBOYpete; I'm still trying too figure it out and learning as the wrenches turn. It's tought being a shade tree mechanic but with alot of leaves missing..................
Old 01-12-2004, 07:45 PM
jj292's Avatar
jj292
jj292 is offline
Old 01-12-2004, 07:46 PM
jj292's Avatar
jj292
jj292 is offline
Fordboy did the trucks ever come with 312s? I know alot of 50's ford junkies and they have said the largest engine avalible in trucks at that time (50's to mid 60's) was the 292. I thought the 312 only came in cars. When I say trucks I mean F100, 250, 350 not the big boys.
JJ
Old 01-13-2004, 09:50 AM
stahlecker's Avatar
stahlecker
stahlecker is offline
I don't believe that they were shipped from the factory with the 312. Looking at some literature from my 64 the 292 it came with was the biggest y-block. When the engine needed rebuilt grandpa put a 312 block in place of the 292. It still has the original 292 heads and intake. But that is a 64 not the 50s like you guys are talking about. Plus Ford didn't do everything the same back then so who knows.
Old 01-13-2004, 10:49 AM
stahlecker's Avatar
stahlecker
Old 01-13-2004, 11:41 AM
jj292's Avatar
jj292
jj292 is offline
I was talking about a 64. The y-block was used from the 50's (not sure exactly) to 64, 65 in some 4x4s. I just never heard of a factory 312 in a truck.
JJ
JPBrecheisen
07-14-2021 07:49 PM
hdshadpar
1961 - 1963 F100 Unibody
06-03-2016 07:04 AM
rustymetal
01-26-2016 03:53 PM
brandon1078
07-13-2009 06:46 PM
Nathan
06-05-2000 07:59 AM
Quick Reply: How to tell the differnts between a 292 & a 312 ?
