pushrods
Old Jan 24, 2016 | 05:45 AM
rustymetal's Avatar
rustymetal
Question pushrods
are 292 pushrods different then 312 pushrods.
thanks for any help
Old Jan 24, 2016 | 07:27 AM
hiball3985's Avatar
hiball3985
thanks for any help
They are the same.
Old Jan 25, 2016 | 04:16 PM
charliemccraney's Avatar
charliemccraney
There are different lengths throughout the years, though.
Old Jan 25, 2016 | 04:25 PM
hiball3985's Avatar
hiball3985
That is something I never really understood. What was physically different that would require the two different lengths?
Old Jan 26, 2016 | 09:07 AM
charliemccraney
The difference is in the heads. 54-55 and 60-64 use the long pushrods. 56-59 use the short pushrods.
The difference would have to be the distance from the deck surface to the rocker stand mounting pads.
While I've never measured that dimension, I have used the short pushrods on 1960 castings and it required the adjuster screws to be turned nearly all the way in. When the same pushrods and rocker assemblies were used on 1957 castings, and the same block, the adjustment was closer to the middle of the screw.
The block these were used on had the deck 0'd and the heads had been milled. Had that not been done, the shorter pushrods may not have worked at all with the 1960 heads.
I should add that you should not mix and match. Use the correct pushrods.
Old Jan 26, 2016 | 10:57 AM
hiball3985's Avatar
hiball3985
Thanks, I always wondered about that. I have some 60-61 heads I could check but the 57 G heads are on the engine so I can't compare them. With the G heads my adjusters are screwed in about 3/4 of the way almost like it could use the longer push rod.
Old Jan 26, 2016 | 12:04 PM
charliemccraney
Earlier heads came with troughs under the rocker stands which would also add to the height. I'm not sure exactly when those were phased out but later heads did not use those.
Another thing that would affect the pushrod length, everything else being equal is the position of the valve in the head.
There is about 3/16" difference between the long and short pushrods. From Mummert's site, 8.320" overall length and 8.125" oal. So you can pull one to measure.
As long as it is functioning well and there are no problems, it will be ok to leave it as it is.
Old Jan 26, 2016 | 03:53 PM
hiball3985's Avatar
hiball3985
My 292 runs like a Swiss watch so I have no plans to make changes. I just started working on a new Y block but don't have a use for it yet. I have an old set of the troughs from a 55 engine, maybe when they stopped the troughs and the head casting difference combination they used the shorter push rod also?
wagonerkl
26
Jul 25, 2011 10:03 PM
fordnut2008
Aug 28, 2008 09:56 AM
bootie
Aug 3, 2005 06:39 PM
Kagey
Sep 23, 2004 06:27 AM
mav4804
Dec 28, 2003 01:40 AM
