'87 1/2 ton radius arm bushings???
Howdy all,
I'm a bit stuck at present. I got new radius arm brackets and bushings for my '87 1/2 ton Clubwagon. My problem lies in the assembly of the new ones since the old ones are darn near unrecognizable. From what I gather, going from rear to front, it goes nut, smaller washer, bushing, bracket, spacer, bushing, and finally, bigger washer.
My problem is the general bushing position. One has a conical end and a hub on the other side that fits in the spacer nice. That would put the cone shape facing forward. The other has a squarish back that has a hub on it's end to fit the hole at the forward part of the bracket. Initially I thought the cone part went inside the rear body of the bracket. The problem is the hub on the other bushing is around 1/4" bigger than the hole in the spacer.
If any of you folks out there have any experience at this I'd love to hear back from you. This'll be the third time I get to dropp the exhaust and crossmember to get at the passenger side. I don't want to do it a fourth. Any pointers will be greatly appiciated!
Thanks,
-John R.
Thanks,
-John R.
My wife'd kill me if her keyboard looked like my manuals. That and I'm old fashioned in the respect that these darn boxes are harder to figure out than paper pages.
Any reason why these are different than my '90 F-150? Different brackets and bushing/spacer configuration.
-John R.
P.S. I'm learning a bunch on this darn van. Not to mention loosing blood on a semi-regular basis. Watch out for the sheet metal around the rear of the motor!
-John R.
Derrick lane
12-14-2010 02:06 AM
codyingersoll123
32
02-28-2009 05:31 PM
mnm99
1978 - 1996 Big Bronco
04-13-2003 07:39 AM
