1978 - 1996 Big Bronco
Need help installing RADIUS arm bushings QUICK.......
Old Apr 11, 2003 | 06:46 PM
mnm99's Avatar
mnm99
I went to install the radius arm bushing and It wouldn't fit???? I have a 4 inch lift with the drop down brackets. I bought bushings from Autozone. They come in these pieces and am told to put it in this order..
-metal cup washer
-large bushing
other side of bracket
-Black spacer
-small bushing
-washer
-Bolt
There is no way the bolt will fit!!!!!!
Is the energy suspension just
-metal cup washer
-large bushing
Other side of bracket
-small bushing
-washer
-bolt..
Someone tell me whats wrong!!!
Need help quick...
1988 Bronco
Old Apr 11, 2003 | 06:52 PM
greystreak92's Avatar
greystreak92
The "black spacer" is my question. What need is there for the spacer? The bracket is only 1/8 " stamped steel. The stock bushings have the compression washers and one half of the bushing on either side of the bracket. Shouldn't be any need for any other spacers/bushings/washers. Now, new bushings WILL have to be compressed a bit when you first install them....thats how i messed up a thread on my passenger side stock raduis arm. So, I bought extended ones when I bought my lift!
Old Apr 11, 2003 | 06:57 PM
mnm99's Avatar
mnm99
whats the order of the new ones?
front washer
bushing
bracket
bushing
back washer
nut
Old Apr 11, 2003 | 07:11 PM
greystreak92
Yep! that should be all you need. I mean thats how the stock ones are set up.
Old Apr 12, 2003 | 06:35 AM
mnm99's Avatar
mnm99
Thats why I'm confused...That's not how the stock ones are setup. My bracket is a Rough Country lift bracket and it's a little over 1/2 inch thick. I can't post a pic so I try this way
------------( O I i o l D--
This is the stock way.........With the stock kit from Autozone. I ordered Energy suspension, Are they any diff?
( = curved washer
O = large bushing
I = bracket
i = black spacer
o = small bushing
i = large washer
D= nut
There is no way I can get the nut on.
Anyone use the energy suspension bushings? how did you set them up?
Thanks
Old Apr 12, 2003 | 11:13 AM
msautry's Avatar
msautry
I used the energy susp bushings on my 89 and you're right, it's tough to make them fit. I shaved a little material off the back side of the rear bushing (the last big washer goes against it) until I could get a couple of threads for the nut to bite on. Didn't have to remove too much, and they tightened right down correctly.
Its an easy, quick fix.
hope this helps
msautry
Old Apr 12, 2003 | 11:50 AM
mnm99's Avatar
mnm99
I was told from someone to leave out the black spacer with the energy suspension bushings. If I do that it will fit ok.
so its....
-Curved washer
-Large bushing ( curverd part foward )
-Bracket
-Small bushing ( curved part facing rear )
-large flat washer
-Nut
How did you install the spacer ( if you used it? ) do both curved parts of the bushings face toward the front and back?
Still not sure??
Old Apr 12, 2003 | 07:35 PM
Mexray's Avatar
Mexray
I used a come-along between the axle/arm and back to the frame - to compress the bushing in front enough to assemble the rest of the stuff and start the nut on the threads....good luck
Old Apr 13, 2003 | 07:39 AM
Dazza's Avatar
Dazza
I've used the Superlift drop down brackets, and with the Kit you dont need to use the spacer due to the thickness of the cast bracket, compared to the original pressed steel one.
Working fine after 4years.
reem98
15
Nov 15, 2023 06:08 AM
frederic
Jul 16, 2021 09:01 PM
Treacy
Jul 5, 2016 02:40 PM
carguy3j
Apr 29, 2016 08:10 AM
Derrick lane
Dec 12, 2010 07:29 PM
