Well, it's time to do the radius arm bushings again, but I'm not sure what order to install them. The picture in the manual didn't match what was on there, but the Ford parts guys says the manual is wrong. So, who's right?
The manual shows the installation (from forward to rear) as follows: Retainer (which I assume is the cupped shaped washer), the mushroom shaped rubber bushing (in front of the bracket), the plastic ring, the cone shaped rubber bushing, the flat washer and finally, the nut (on the back side of the bracket). The way it was installed is: the flat washer, the cone shaped bushing, the plastic ring (in front of the bracket) and the mushroom shaped busing, the cupped washer, and the nut on the back side of the bracket.
My 1989 Ford manual has it as....
Retainer, inner insulator, then on the other side it goes retainer, outer insulator, shield (v-6, RH only), washer and nut.
I have the same thing to fix. Put it on jacks and tried to take off the nut that holds thr springs on but it was dont way too tight. Cant get it off. was hoping I couyld, dont want to pay some one to do it.. Any suggestions? Its the right side, on a '86, V6, Supercab. Thanks in advance.
Jeremy
when ever you have a bolt that wont budge first spray it with penetrating oil and let it sit for a good while. then use animpact wrench with a high torque rating or put a wrench on it and get as much leverage as a possible.
Thanks Ken, I've got the manual as well but the picture isn't exactly what I'd call clear so it's hard to tell what is what. The parts guy is making me second-guess the manual. My interpretation of the manual is as follows:
Retainer = cup shaped washer
Inner insulator = mushroom shaped bushing
Retainer on other side = plastic ring, although it's difficult to tell what the correct orientation is.
Outer insulator = cone shaped bushing
Washer = flat washer
Now that I've thought about it and looked at my truck, I think the manual is correct (and so is the truck). From the last time I did the job, I seem to remember that the flat washer couldn't fit over the non-threaded portion of the raidus arm, so it must go on last. That means the cupped washer (retainer) goes first and the mushroom bushing goes next with the cupped washer. What's left is to get the orientation of the cone shaped bushing and the plastic retainer, but I should be able to figure that out once it's apart.
you're right, that nut is extremely tight. I did mine in the driveway...i had the truck jacked up securely and i used a tight fitting wrench and pushed it with BOTH legs while holding onto the frame!! impact wrench wouldn't budge it....but mine is a cheapie. used my legs little by little and then finally could use my arms! quite a sight i'm sure!!! Kent
I have a '95, 2wd, that has a clunk, clunk sound when I go over bumps. I replaced the shocks and the truck steers and handles good. So, is this probably bad radius arm insulators? Is there any other check I can do before I spend time and money to ensure this is the problem? I would like to do it myself, but I doubt I can get a nut off that's been torqued to 200 ft-lbs! I suppose Ford wants an arm and a leg to repair it. Any problem with just letting it go clunk, clunk?
Mine made that sound too and it was the radius arm bushings. If you don't fix it, it throws your alignment off a little and makes the front end a little loose. I regular garage can probably fix it instead of ford and it may not be so bad. KS
