Electric motor running on ACC?
03-08-2017, 06:40 PM
When I turn my truck to ACC (accessories), I hear an electric motor running. It's continuous. It doesn't sound like the fuel pump. Any ideas?
03-08-2017, 07:09 PM
heater fan ? it will run unless vent selector is turned to "off".
03-08-2017, 07:33 PM
I forgot to mention I checked this and made sure it was off. Good suggestion though.
Quote:
Originally Posted by
joey2fords
03-08-2017, 07:43 PM
i always thought it was a weird set-up. why not just have an "off" position on the fan switch ?
fuel pumps should not run in the ACC position, but if you want to remove all doubt just pull the efi relay.
03-08-2017, 07:47 PM
on
Is it a diesel? Maybe an electric vacuum pump?
03-08-2017, 09:00 PM
No sir, it's a 5.0 gasoline.
ciamcoop
03-08-2017, 09:05 PM
Thanks. Where is the EFI relay located?
joey2fords
Nitesaber
07-22-2011 08:53 PM
schlepprock250
08-29-2008 03:38 PM
BadTriumph
Fifth Wheel & Gooseneck RV Towing
05-14-2008 06:29 PM
scrapyardking
General Automotive Discussion
08-31-2007 08:44 PM
Martys82
09-14-2003 08:54 AM
