Electric motor running on ACC?
When I turn my truck to ACC (accessories), I hear an electric motor running. It's continuous. It doesn't sound like the fuel pump. Any ideas?
heater fan ? it will run unless vent selector is turned to "off".
I forgot to mention I checked this and made sure it was off. Good suggestion though.
Originally Posted by joey2fords
(Post 17015997)
i always thought it was a weird set-up. why not just have an "off" position on the fan switch ?
fuel pumps should not run in the ACC position, but if you want to remove all doubt just pull the efi relay. |
Is it a diesel? Maybe an electric vacuum pump?
No sir, it's a 5.0 gasoline.
Originally Posted by ciamcoop
(Post 17016107)
Thanks. Where is the EFI relay located?
(Post 17016094)
