Electric motor running on ACC?
Old 03-08-2017, 06:40 PM
Glenn54's Avatar
Glenn54
Glenn54 is offline
When I turn my truck to ACC (accessories), I hear an electric motor running. It's continuous. It doesn't sound like the fuel pump. Any ideas?
Old 03-08-2017, 07:09 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
heater fan ? it will run unless vent selector is turned to "off".
Old 03-08-2017, 07:33 PM
Glenn54's Avatar
Glenn54
Glenn54 is offline
I forgot to mention I checked this and made sure it was off. Good suggestion though.
Old 03-08-2017, 07:43 PM
joey2fords's Avatar
joey2fords
i always thought it was a weird set-up. why not just have an "off" position on the fan switch ?
fuel pumps should not run in the ACC position, but if you want to remove all doubt just pull the efi relay.
Old 03-08-2017, 07:47 PM
ciamcoop's Avatar
ciamcoop
ciamcoop is offline
Is it a diesel? Maybe an electric vacuum pump?
Old 03-08-2017, 09:00 PM
Glenn54's Avatar
Glenn54
Glenn54 is offline
No sir, it's a 5.0 gasoline.
Old 03-08-2017, 09:05 PM
Glenn54's Avatar
Glenn54
Glenn54 is offline
Thanks. Where is the EFI relay located?
Nitesaber
07-22-2011 08:53 PM
schlepprock250
08-29-2008 03:38 PM
BadTriumph
Fifth Wheel & Gooseneck RV Towing
05-14-2008 06:29 PM
scrapyardking
General Automotive Discussion
08-31-2007 08:44 PM
Martys82
09-14-2003 08:54 AM
Quick Reply: Electric motor running on ACC?
