1991 F250 Speedo/Odo not working
Hey all, new to the forum and to the ford truck world so thank you in advance for all the help! I recently purchased a 1991 Ford F250 Custom with the 5.8L engine and manual transmission as a project/weekend truck and am loving it thus far. I have done a few things over the past month that I've had it:
~oil and filter change
~air filter
~plugs and wires
~new windshield wiper motor
~new/used wheels and tires
~new cat, the old one had fully rusted off
~I have replacement monroe shocks, just haven't had time yet to install
~new rear drum brakes
Rust wise, the ole girl isn't terrible other than the floor boards, which are good enough for use, but will down the line cut all that out and put in new pans when I acquire a welder.
I've been doing a lot of reading on here since I bought it and found may issues with the speedo/odo that other people were having, but could use some more input. Thus far the only real troubleshooting I have done on the issue is checked the fuse, which is good to go. Since both were not working I did not want to pull the cable out and start taking things apart without some more input, and I just haven't had the time.
So my question is, where do I start? Since they are both not working, would that mean its more of a cluster issue? Any and all input is welcome and thanks again in advance. I am not a mechanic, but haven't met too many projects that I can't work through. Thanks!
~air filter
~plugs and wires
on
Disconnect the cable at the trans/t-case and spin it with your hand, if the speedo needle moves you know the cable and cluster are good. The bad news is that means the drive gear inside the trans/t-case is stripped and has to be replaced. If that test doesn't move the needle then it's the cable or the speedo, and so you know the speedo module itself can be changed without removing the whole cluster from the dash, just remove the dash trim and the speedo lense and trim and then the individual modules can be pulled out of the cluster.
Received 3,110 Likes
on
on
Perfect, thanks so much for the help, hopefully next week I will have some good news to report. I know I can buy a new cable and a that I can buy a new gear for the cable if either of those are the issue, but what if the gears inside the tranny are worn. What steps would I take there to get that fixed or is it even worth it.
on
Here's a pic of the Warner T-19, output shaft is 7061, speedometer DRIVE gear on the output shaft shown as 17285 (in pic at lower left).
But this is only the basic part number, so he'll have to look at his DRIVE gear to see how many teeth it has and its color.
on
on
nrogers130
04-08-2015 09:45 PM
hedgeapple
08-04-2004 01:52 AM
nudgey
01-05-2004 05:31 PM
