Speedometer bouncing under 35mph
Old Apr 7, 2015 | 11:52 AM
nrogers130's Avatar
nrogers130
I have a 1968 f100 with a 360ci. My speedometer is bouncing until i reach about 35mph. I only have a basic understanding of how the system works. I Believe the coil is catching, then releasing on the wheel until higher speeds when it smooths out. If this is the case, should I just lubricate the whole system or replace everything?
Old Apr 7, 2015 | 12:00 PM
HIO Silver's Avatar
HIO Silver
Possible maladies:
  • Worn odometer/speedo gear in the instrument cluster
  • A speedo cable that is not fully seated and threaded into the back of the cluster
  • Worn/missing teeth on either the drive gear in the trans or driven gear on the speedo cable.
  • Speedo cable is unraveling in its jacket until it binds to provide a steady reading.
Old Apr 7, 2015 | 04:40 PM
willowbilly3's Avatar
willowbilly3
Start by cleaning and lubing the cable real good.
Old Apr 7, 2015 | 05:05 PM
JEFFFAFA's Avatar
JEFFFAFA
2X. Only make it something thin like 3-N-1 household oil. Or I know Harley Davidson has a real good cable lube. Pricey though.
Old Apr 8, 2015 | 01:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Inside the speedo cable housing is a woven steel core that is supposed to be lubed every so often, but most people are unaware.
When the lube dries out, the woven steel core binds up inside the housing, eventually snaps. Auto parts stores sell a universal woven steel core kit. Cut it to length, install in the housing.
Originally, Ford recommended white lithium grease for the core, but today...most people use graphite as it doesn't attract dust like grease does.
Old Apr 8, 2015 | 02:37 PM
JEFFFAFA's Avatar
JEFFFAFA
[QUOTE=NumberDummy;15251176]Inside the speedo cable housing is a woven steel core that is supposed to be lubed every so often, but most people are unaware.
QUOTE]
Yep. Or a cut to fit 17262 cable kit. The reason I didn't mention it is because here in AZ I've found that most times the inner cable core wears in to the woven steel core that Bill mentioned. Lubing it doesn't help so therefore a new cable core won't either. I'd try lubing it 1st. Maybe OP will get lucky and it's only the dried up grease like in Cali. But you're prolly going to end up buying a new speedo cable assembly like I've ran across here.
Old Apr 8, 2015 | 03:10 PM
NumberDummy
Ford sold several different 17262 core kits (obsolete on D2D), but since auto parts stores sell the same kits, there's no reason to list the Ford kits, that were only available from dealers.
Old Apr 8, 2015 | 03:20 PM
JEFFFAFA's Avatar
JEFFFAFA
True story Bill. Back in those days I worked at Earnhardt Ford. We stocked and sold these universally since they were long and a cut to fit kit. As you know.
C5AZ17262B, .13 core diameter...135" long.
B9T17262E, .15 core diameter....175" long.
Old Apr 8, 2015 | 03:59 PM
NumberDummy
Their advertising catch phrase: No Bull!
My sister bought a new '75 LTD Country Squire there, it was the first wagon I ever saw with cloth seats.
Old Apr 8, 2015 | 04:15 PM
JEFFFAFA's Avatar
JEFFFAFA
Their advertising catch phrase: That Ain't No Bull!
Ha-ha! You are correct. The reason he said that is because it had it's **ts cut. It was then a "steer" he was sitting on.
Old Apr 8, 2015 | 09:45 PM
orich's Avatar
orich
A bent out of shape bend in the cable housing can cause it to bounce around low speeds..
You figure the yrs of use the cable has gone through.
A few days ago saw a nos speedometer replacement on ebay But ,I'd start by installing a new cable and housing, then replace speedometer itself if needed.
A lot of us just built are own custom dash with aftermarket electronic gauges.
Orich
cabloom300
Jan 20, 2014 08:08 AM
ErrorS
1978 - 1996 Big Bronco
Dec 2, 2011 10:37 AM
ol orange
Aug 14, 2010 12:48 PM
Dustin_86
Nov 1, 2004 10:17 PM
hedgeapple
Aug 4, 2004 01:52 AM
