66 F100 weird rear suspension?
Hello again FTE,
I am planning on doing the DJM 3/4 lowering kit on my 66. However, I seem to have a rear suspension setup that seems different from anything I can find on the world wide web. In the rear I have a leaf spring, gas shock, and a short coil spring. I am trying to figure out how this will effect my plans for lowering kit. Any insight would be appreciated. Thanks see pic
Personally, I would just start by pulling a leaf or two. Coils tend to ride better than leaves...
Hello, and welcome to the site. Nice looking truck, by the way.
I see from your profile you are in Oregon. There are a couple good spring shops in Portland that can work with you and build what you need / want. Prices are surprisingly reasonable.
I would remove the helper coils and see where your truck sits. Then I would look into changing things.
Sometimes old worn springs can give you the ride height you are after.
Good luck.
Good luck.
Good luck.
Good luck.
undertakerman
07-01-2010 04:59 PM
nate5812
11-04-2004 11:20 AM
skater2570271
12-01-2003 01:39 AM
