66 F100 weird rear suspension?
2 Attachment(s)
Hello again FTE,
I am planning on doing the DJM 3/4 lowering kit on my 66. However, I seem to have a rear suspension setup that seems different from anything I can find on the world wide web. In the rear I have a leaf spring, gas shock, and a short coil spring. I am trying to figure out how this will effect my plans for lowering kit. Any insight would be appreciated. Thanks see pic :-drink |
overload spring set up from the 70s , early 80s
You can eliminate the helper coil, and rebuild or replace the leafs if they aren't strong enough..
Removing those helper coils will likely lower it a bit, and removing the thick over load leaf at the bottom of the spring pack will lower it some more and soften up the ride. You might need shorter shocks depending on how much you lower it.
About a month ago my brother installed some homemade coil helpers like that on his '04 F350. The stock leaves were a bit weak for some of the loads we carry and they were rough as well. After installing the coils, it rides WAY better in the back and carries a load a bit better as well.
If I were to just get rid of the helper springs and replace with bigger leaf springs, how many leafs would I want? Looks like my choices from LMC are 7,8, or 9. Keeping in mind this is becoming a street cruiser, not going to be hauling any heavy loads.
Originally Posted by 66 Old Red
(Post 16982718)
Hello, and welcome to the site. :-wink Nice looking truck, by the way.
I see from your profile you are in Oregon. There are a couple good spring shops in Portland that can work with you and build what you need / want. Prices are surprisingly reasonable. I would remove the helper coils and see where your truck sits. Then I would look into changing things. Sometimes old worn springs can give you the ride height you are after. Good luck. |
Originally Posted by Roger Carter
(Post 16983156)
