95 F-Super Duty
95 F-Super Duty
95 7.3 has stalling and bucking usually after you run the truck for 20 miles or so. Suspected o rings because of black fuel filter and a little blue smoke when first started. So I pulled injectors put new rings on and gave it a fresh oil change. The bucking is still there though but not nearly as bad. Any ideas?
no less than 40 PSI in 3rd at WOT
here is a hit list of stuff I did when I got mine to share with you
https://www.ford-trucks.com/forums/1...sel-truck.html
fnfast88
61
09-16-2015 03:52 AM
