Will first gen psd headstuds fit 7.3 idi?
Old 01-16-2017, 12:18 PM
Greatwhite94's Avatar
Greatwhite94
Greatwhite94 is offline
So found a really good deal on some first gen psd headstuds and i want to eventually throw a turbo on my 7.3 idi na and i know the first thing you have to do before increasing compression is replace headstuds. So will the headstuds for a psd fit my 94 7.3 idi na?
Old 01-16-2017, 01:06 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
98% sure psd uses 12mmx1.75, they do seem to be the same length though, at least the long ones.
Old 01-16-2017, 09:50 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
7.3 with head bolts can handle up to about 20 PSI, IIRC. If you keep it to 10-12 psi max -- which is about what you can get out of a banks/hypermax/ats turbo kit and a stock IP -- you are fine.
Remember, these kits were sold without headstuds being required.
Old 01-17-2017, 09:17 AM
Jarkill's Avatar
Jarkill
Jarkill is offline
I think it was Tom that said he just re-torqued the stock head studs and it's all good for 10-12 psi. Like Macrobb said, Those kits are for stock studs and pumps anyway. But, if you already got her torn down, studs wouldn't hurt. Peace of mind
Old 01-17-2017, 11:07 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
7.3PSD is 12mm, the 7.3IDI is 1/2", so no. R&D has the 7.3IDI stud kit for a very good price.
You can do the studs one at a time if you're careful, at least I know you can on the 6.0. Just take the head bolt out, thread the stud in, paint it with Ultra Torque and then spin the nut down. Make sure you do the full torque before going on to the next one.
Old 01-17-2017, 05:04 PM
hairyboxnoogle
After my experience of breaking some bolts trying to get them out, im not sure i would even try to retorque them, unless you pulled em and lubed them (assuming you could get them out) Also, 7.3 headbolts permanently stretch when torqued just a little over stock spec. 6.9 bolts however, seem to be alot better quality.
Fitzgerald_welding
Competition
11-28-2010 09:42 PM
4rdzilla
11-27-2005 11:19 PM
RLSage2
09-25-2004 06:29 PM
RawPower
01-12-2004 10:11 AM
Quick Reply: Will first gen psd headstuds fit 7.3 idi?
