1978 - 1996 Big Bronco
Hunting a miss, idles badly, inconclusive codes galore
Old 08-11-2016, 09:11 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Please check this thread out:
https://www.ford-trucks.com/forums/1...es-galore.html
Old 08-16-2016, 05:32 PM
Encho's Avatar
Encho
Encho is offline
There are new developments ^
Old 08-17-2016, 06:33 PM
masseysbronco's Avatar
masseysbronco
masseysbronco is offline
I'd say clear all codes, run all tests again with engine at normal operating temperature, and suspect the TPS?
Old 08-17-2016, 06:42 PM
Encho's Avatar
Encho
Encho is offline
No, that wasn't it, already got a new Motorcraft one in there to no avail so I guess I got myself a TPS spare. I'll go with the ECT next, which is actually one of the codes at hand (ran codes again today, warmed the truck further up, got the same codes back).
Old 08-19-2016, 08:00 PM
Encho's Avatar
Encho
Encho is offline
ECT replaced, still a no go, please check the link in my first post, share any thoughts that might help.
Old 09-09-2016, 04:22 PM
Encho's Avatar
Encho
Encho is offline
ICM replaced, the problem persist...
Old 09-09-2016, 11:01 PM
EDC8008's Avatar
EDC8008
EDC8008 is offline
Hate to ask the stupid question but ran into it a ton when working for U-Haul, when you put in the TPS you started with it about 45 degrees clockwise then rotated it counterclockwise to put the screws in? If not the pin is on the wrong side of the lever and will never move. Had several trucks back then with drivability issues due to the TPS an di even it did it on one of my own.
Old 09-10-2016, 12:17 AM
Encho's Avatar
Encho
Encho is offline
I really hope I installed the tps wrongly, that would be quite easy to correct. I'll check tomorrow, but from the miss I'm having I suspect it isn't the cause.
Old 09-10-2016, 05:16 AM
EDC8008's Avatar
EDC8008
EDC8008 is offline
I gotta do cap, rotor, plug wires, plugs, reset the base timing and find a stinking vacume leak on mine. I got a idle miss on mine. My old Bronco II had the miss due to base timing, when I rest that ran smooth as silk.
Bought mine from a friend in California and have just been busy (got married again, new job, dealing with 2 houses now) to really work on it but hope to have some time soon.
Old 09-10-2016, 02:57 PM
Encho's Avatar
Encho
Encho is offline
Well, got all the way down to the TPS, and found out I definitely installed it correctly. Looking at the TB lever I seated the TPS retarded (turned counter clockwise) against the lever, then turned it clockwise until the holes for the bolts were aligned and tightened the sensor in place. I'll test the wires for spark tomorrow, see if there is any crossfire... Still think the cause is somewhere else.
Old 02-04-2017, 01:05 PM
Encho's Avatar
Encho
Encho is offline
Well, some new info, still without a working truck, please check the other thread (link in the first post).
ItsAFord55
03-13-2012 06:51 PM
duncannon6
Bronco II
10-30-2006 01:23 PM
choppersinc
1983 - 2012 Ranger & B-Series
03-01-2005 08:29 PM
Quick Reply: Hunting a miss, idles badly, inconclusive codes galore
