Main Cap Bolt size
Main Cap Bolt size
I have been looking for a main cap bolt for an FE engine with the stud to support the rear sump oil pickup. I found the one linked here but it is advertised for a 351 w then says further down that it will also fit FE style engines. Is that the case? Do they really have the same size main bolts?
https://www.vividracing.com/catalog/...FZq6wAodAKQP-Q
Off the top of my head I would've said no, but, before I stuck my foot in my mouth (again ), I checked the parts catalog.
The answer is yes, they are the same bolt.
From the catalog, for trucks with a 360.
Bolt, main bearing w/stud
½"-13 X 3/8"-16 X 4 11/16"
P/N D6TZ-6345-A
Last dealer cost $8.14, last list $13.57
The catalog shows the same part number and spec. also fits the 351W in the Econoline van.
I checked and no dealer or obsolete supplier has a NOS part.
P/N D6TZ-6345-A
From the catalog for trucks with a 360.
P/N D6TZ-6345-A
P/N D6TZ-6345-A
1966 F100 352 4WD / 1973/76 F100/250 360 4WD / 1975/91 Econoline 351W
No one has any of these part numbers.
Clueless ebay seller listed the part number: C6TZ-6345-C = 1966/74 F100/250 240/300 I-6 4WD; 1975/96 F100/250 300 I-6 4WD
1969/74 Econoline 240/300 I-6 / 1975/91 Econoline 300 I-6.
1966/68 Bronco 289 / 1969/77 Bronco 302 / 1980/96 F150/250 4WD & Bronco 302.
Does NOT fit 1966/76 F100/250 352/360 4WD or 1975/97 Econoline 351W
Fastolds
24
12-01-2012 05:50 PM
77'FORD_man
04-17-2012 03:51 PM
gibsonj
1997-2006 Expedition & Navigator
06-30-2006 11:04 PM
scclarkf350
10-25-2004 04:43 PM
