Alternate Fuel - CNG System Questions
Old 08-22-2003, 10:46 PM
trav639's Avatar
trav639
trav639 is offline
Hi All,
Anyone out there have a factory dual fuel vehicle using unleaded gas and CNG ? I have a '96 E350 (former GSA fleet vehicle) and I have some questions about the CNG system operation.
Main questions so far:
1. Is there any sort of fuel level indication for the CNG system ?
2. Does filling the CNG system work like gasoline in that you can put only as much as you want or do you fill it full each time based on some system measurement like pressure ?
Thanks in advance for any and all help.
Terry
Old 08-23-2003, 01:23 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
There should be a pressure gauge on the tank, if it is visible. If there are wires coming out of a sensor on the tank, it is wired to the gauge.
Old 08-23-2003, 08:49 PM
javi2001's Avatar
javi2001
javi2001 is offline
Natural gas can not be compresed to liquid form at ambient temperatures, so only way to know how much is in tank is by pressure reading, BUT pressure readings are wide afected by temp, so if your gas tank receive direct sun, or it is located side to exhaust system, readings will change also with tank temperature :-s
Regards;
AZFordLover
2017+ Super Duty
22
09-07-2021 12:30 AM
kpchambers
2017+ Super Duty
12-01-2016 02:01 PM
Snakeoiljoe
06-22-2016 04:31 PM
okrp
Bio-diesel, Propane & Alternative Diesel Engine Fuels
03-15-2013 11:23 AM
Quick Reply: Alternate Fuel - CNG System Questions
